Check engine light on my Duramax with a Cadillac gauge cluster.
Results 1 to 7 of 7
    The real WetWillie!! Boosty's Avatar
    Default Check engine light on my Duramax with a Cadillac gauge cluster.
    I know a few guys here tricked out there Duramax trucks and put the Cadillac dash set ups in them. Well since I had my cadi dash installed my check engine light is now on all the time. I had a local shop check it out and they said it was an error having to do with something having to do with a heater or?? Anyone know a fix for this or a shop that has resolved this in the past.
    I guess I could pull the bulb but what would that help??
    Senior Member HemiHydro's Avatar
    Northern California
    Default Check Engine Light
    I'm thinking Glow Plug !!! Caddies don't have one.
    Funny I didn't think newer Diesel trucks had glow plugs. That is probably what it is...
    Anyone know?
    The HMFIC HWLaser23's Avatar
    fontana ca
    i dont think chevys have glow plugs i think it has a intake heater i cant remember the dodge cummins has the same thing your ecu might be picking up a bad reading from the gauge cluster may be you forgot to plug sumthin in????
    BLACK SMOKE DON'T MEAN ITS BROKE
    Northern California
    Default Glow Plug
    My 2003 DuraMax HAS a Glow Plug. My thought is that the Caddy Instrament Cluster lacks the ability to send a signal to the Durmax computer, thus Check Engine Light = Error, Glow Plug.
    I will put a reader on it and see what it says. It has been a while since I read it..
    Ultra 27 Shadow shippingguy's Avatar
    Murrieta, CA/ Ft. Mohave, AZ
    My 06 has glow plug as well.
