Allison 5 speed?
Results 1 to 3 of 3
Allison 5 speed?
    Placentia, CA
    Default Allison 5 speed?
    What is the best way to get as much tranny fluid out as I want to do filter and fluid changeover to Hyguard?
    steveo143 AKA DiMarco 21 II
    TPC
    TPC is offline
    You who rock I salute you TPC's Avatar
    Catalina Island
    The spin filter is for the solenoids only change it, then simply drain and refill the main pan at the drain plug.
    Supposed to be fine for the change over to Transsyd or the newer Dex.
    If you are running hot then you either have too much or too little fluid.
    Even a pint too much will raise the temp.
    I did this method 53K miles ago and all is well.
    Hat
    Hat is offline
    Jan 2010
    Quote Originally Posted by steveo143 View Post
    Many allisons have a converter drain plug.....as well
