There has got to be something wrong with this pic
Results 1 to 6 of 6
    Default There has got to be something wrong with this pic
    I don't know this truck sounds way too cheap...I'm suposed to look at it tonite. He says the clutch just got replaced. Isn't 60k kind of early to loose a clutch. What else should I be looking for problem wise. Is this year prone to any typical issues? It just sounds like way too good of a deal.
    http://www.ksl.com/emedia/its/slc/97...ter=ksl/newhl2 OOPS looks like all I got was the pic, I'll try again. He's asking 5k, 2003, 2500 gmc. 60k miles
    http://www.ksl.com/index.php?sid=0&n...iew&ad=2141950
    those trucks were wayyyyy to ease to unplug the odometer on there was actually a connector you could unplug on the back of the ipc to disable the odometer only, jus a fyi
    s480@18lbs nto 325cubes of whoopass : ) turbo boyz
    T&Y
    T&Y is offline
    Sep 2009
    Salvage title? 60k on a clutch seems low but who knows who was driving this or how they were driving it. For all you know they thought it was a prerunner and beat the crap out of it the entire time. I'd bring a creeper and get under the truck with a nice bright flashlight looking for cracks, seems in the body, etc. Make sure you go somewhere you can test out the 4wheel drive in all it's gears.
    On Edit: be sure to check the dash vin with the door vin just to be sure. 60k on and 03 isn't really that crazy for miles.
    Nov 2008
    Orangevale CA
    It say's all city miles,, someone could wear out a clutch in 60k city mile's , It has new tire's , ...............E
    Senior Member SConA's Avatar
    San Dimas
    Check the year of the truck. Mileage seems low for a 17 year old truck
    Specifications
    Body:
    Truck
    Make:
    GMC
    Model:
    Sierra 2500
    Year:
    1993
    Mileage:
    60000
    Number of doors:
    2
    Exterior condition:
    2 Good
    Exterior color:
    Tan
    Interior condition:
    1 Excellent
    Interior color:
    Brown
    Type of fuel:
    Gasoline
    Type of transmission:
    Manual
    Drive Train:
    4 Wheel Drive
    Orlando.FL
    We used to be in the bus business and had a woman who would go thru a clutch a day. Needless to say she was gone after a coulle of clutches.
