Diesel Smog Check
Page 1 of 2 12 LastLast
Results 1 to 14 of 28
Diesel Smog Check
    Senior Member Luvnlife's Avatar
    Castaic, Ca
    Default Diesel Smog Check
    What are they looking for? I have a 2004 Duramax, should I take the Hypertech out when I go. Thanks
    While I'm not the final vote here to the best of my knowledge any modifications to your engine or emmission system will need to have a CARB# assigned to be legal. Example: I have a '01 Dodge TCD with an Edge stack-on. The unit I have has a CARB# assigned and affixed to the unit itself. If the tech is doing their job and on the ball they will pick that up on visual inspection along with the "gap" where the factory particulate trap/converter used to be. When they plug in their scanner changes to the ECM are a no-brainer. Perhaps someone with more knowledge could elaborate further on the subject of the ECM and does it "know"/ "remember" that it has /had a stack-on unit. That along with the CARB# will be your answer. Just my $.02
    Apr 2010
    las vegas
    take it off to be safe
    Senior Member lowgear351's Avatar
    Jul 2009
    newcastle ca
    There looking to bend you over and take as much money as they can. The smog tech told me my exhaust temp gauge has to be taken off my manifold and a plug put in .
    Castaic, Ca
    Quote Originally Posted by aquaholicbum View Post
    Yes, I will. Other than that the truck is stock so they can't say anything unless they pull stuff outof thier ass. Like a this is bad or that is bad.
    Castaic, Ca
    Quote Originally Posted by lowgear351 View Post
    That's what I'm afraid of.
    Costa Mesa, CA
    Find a new smog shop
    2002 Ultra 21 XS
    2000 Ultra 19 Shadow
    Senior Member JakeC.'s Avatar
    palmdale ca.
    they shouldn't really mess with you. just take the programer out to be safe and you should be good to go. as for them saying to take the egt sensor out of the exaust manifold, thats just stupid. it does not add power, its really just there to keep you from burning you engine down when towing or under heavy load situations.
    Costa Mesa, CA
    Quote Originally Posted by JakeC. View Post
    Agreed!
    If you can take it to the dealer with the gauges in and not void a warranty, the smog guy should'nt give a crap anyhow. They are there to monitor what your truck is doing. Just re-program the PCM back to stock, put the factory exhaust (DPF & DOC) back on, hook up all the sensors and go smog it. I have PCV, re-routed, EGR blocker plate and a ton of other shit done to my truck. Getting it to pass isn't that tough if you know what your doing, and the smog guy does too. Stay away from the gas station smog shops and go to someone who knows diesels.
    2002 Ultra 21 XS
    Ralphs club member LSXINDUSTRIES's Avatar
    Dec 2009
    Van Nuys, CA
    Gauges will not make your vehicle fail visual inspection at smog. They dont for gas vehicles, diesels are no different in this respect.
    “I am on a drug. It’s called Charlie Sheen. It’s not available because if you try it, you will die. Your face will melt off, and your children will weep over your exploded body.”
    New here Beer:30's Avatar
    Bakersfield, CA
    As long as your DOC is still in place, put the tune back to stock. They will do a visual inspection and then a "puff" test. They floor the throttle and snap it shut. They see if there is a large or small cloud of smoke. The tuner will add some smoke, even on a small tune - so, take that off and you shouln't have any issues with your year/model.
    EDIT: also make sure you don't have any "Superchips", "EDGE", "BANKS" or similar stickers on the truck. I went to a smog class and they are teaching to look for "visual" things like that.
    Originally Posted by gn7 Its amazing any of us can even get back to shore each outing with those old tech POS we use.
    [IMG]MVC-039F.jpg[/IMG]
  13. #12
    Steady Rollin
    Corona
    My 07 Duramax is stock and it'll smoke if you mat it. This is such a f'ing scam.
    The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants.
    -- Thomas Jefferson
  14. #13
    Castaic, Ca
    I got the smog done yesterday and passed. I took the Hypertech out and no problems. Tech said most of it is a visual to make sure any add ons are California approved. The computer really doesn't read anything and they don't even put it on the running test, just plug it in. Basically Cali just wants another $10 smog cert and to make sure any companies of any add ons have paid there money for their California smog legal status. I'm sure glad I can help Cali get out of their budget crisis
  15. #14
    Senior Member jetboatrich's Avatar
    Sep 2008
    Saint Charles, Illinois, United States
    Quote Originally Posted by Luvnlife View Post
    California Sucks
