Ford Truck over head computors
Results 1 to 2 of 2
    Default Ford Truck over head computors
    A month or so back, my over head computor became intermittent, then quit, I priced them out at Ford @ 250.00 plus. I messed with it one day. making it work by pulling on the connector, figured it was a bad connection, tried contact promoter it worked for 20 minute then quit completely. A few weeks passed, figured one would popp up on ebay cheap enough. I found places that repaired them for $50.00 and another that would sell a kit, with instuctions for $35.00, that said 7 mod's/improvements. Well this got my couriosity going, I pulled the coputor from the truck, and opened it up. First off the repair kit included solder, so soldering was a given in the fix. I found seven surface mount resistors on the board, four were cracked solder joints on one side, and others showing cracks in the solder. I took the module to work, and resoldered the resistors, back to the circuits, and popped it back in. It actually worked I pretty sure I'm bullet proof for the month of June
    Junior Member WOWCHAD's Avatar
    Milwaukee'ish
    Sleek I've always had good luck with powerstrokeshop.com for my FORD parts. If you can't find it on-line just call them. Chad
    The CUSTOM Cable Guy
    Milwaukee'ish, WI
