ford trans question
Results 1 to 9 of 9
ford trans question
    Default ford trans question
    just got a 86 f350 diesal has the 7.3 turbo in it and 4 speed trans. its a pain in the ass to get into 1st or 2nd when at a stop. once in gear and under way shifts great and smooth. what could be causing this? air in the lines? need adjusment?
    www.ATSdiesel.com ATS_Diesel_Tech's Avatar
    Jul 2010
    Colorado
    Do you mean that it's not wanting to downshift as your coming to a stop, or it feels like it's starting out in higher gear on take-off?
    Senior Member pwerwagn's Avatar
    Los Lunas, NM
    I think he is talking about a standard....not an auto.
    Id check the hydraulics and throw out bearing. That could be causing the hard to get in gear at a stop syndrome. Im not sure on your truck, but on my old cummins I put south bends HD hydraulics in there and it helped make the truck much easier to get into gear at a light.
    --Jeff
    1985 Fineline Centurion tunnel, 1988 200hp merc, "Still Halfast"
    2001 Carrera 257 Effect X, Twin 2000 Pro Max 300's, "Halfast^2"
    Close to the water...
    Quote Originally Posted by LAFD View Post
    If this is a manual trans, the clutch master and slave were a problem, had a explorer the factory replaced several times. Had to change it last year again the new set up works fine.
    hey everyone sorry didnt notice anyone replied to this. its a 4 speed manual. when stopped trying to put it in first or second is a pain. but once in gear shifting threw gears is really smooth. downshifting i have to tap the gas to get the right rpms just right and it slides right into gear. reverse is hit and miss sometimes its smooth sometimes it grinds.
    BIGJOEDUCKSLAYER BIGJOEDUCKSLAYER's Avatar
    SACRAMENTO
    It is a release problem without a dought
    BIG JOE SSMF When it rains, we pour
    thats what i was thinking hope adjusting it does the trick.
    Jul 2010
    Colorado
    This could be because of the pilot bearing not releasing or also synchros. If you come to a stop in 3rd gear and then try shifting into first and it does not want to engage then it's most likely the pilot. If it does then shift nicely into first gear then that would point to synchros.
    cool thanks next time i drive it i will try the 3rd to 1st dealio.
