Originally Posted by
Backtanner
I'm not doubting anything here but is there a way of checking the return line leaking and not the injector itself. Just did all 8 last June with remans from Pensacola Inj. I haven't heard the best reviews about their remans but hell I haven't heard of a reliable LB7 replacement injector either. And you are right, pax side is probably a couple hour job, with the driver side being the challenge (a 5mm shallow 1/4 dr bit socket made it's way to my toolbox in case I ever had to do these again). What is the injector removal tool? When doing them last time it consisted of channel locks to wiggle em loose and then prying them up.
