Its Alive!!!!
Results 1 to 10 of 10
Its Alive!!!!
    Cantard 71hallett's Avatar
    snow bank
    Default Its Alive!!!!
    Finally got my tow vehicle done. 1983 chev with cummings 5.9.
ID:	6835   Click image for larger version.
    Colts fan & Stoker owner RitcheyRch's Avatar
    Santa Clarita Valley
    Very cool and should be smog exempt
    www.facebook.com/RitcheyRch
    "I didn't pay them for sex, I paid them to leave"
    Charlie Sheen
    Life is all about ass, you're either covering it, hauling it, laughing it off, kicking it, kissing it, busting it, trying to get a piece of it, or behaving like one.
    snow bank
    Quote Originally Posted by RitcheyRch View Post
    Down here they only go back to 1988 everything older than that never has to be tested.
    Senior Member Can Am 75's Avatar
    Please give more specs and name of qualified installer. Approx costs and changes required to do this job. I would be interested in this swap as my 6.2 doesnt get as good mileage as Cummins would and should be a better all around package.
    Brian
    Thats nice Paul.....dang I want a dodge in my new chev. Seriously my cummins was awesome and got 17+ mpg when not loaded.
    Just Me snoc653's Avatar
    Eastern Iowa
    Nice!! Is that an early Cummings with manual fuel injection?
    Mar 2010
    Nashville,TN
    Its a cummins not cummings. Just a big pet peeve of mine
    And yes depending on what year motor it was it either has the P-pump or the VE which have fuel screws to turn up the amount of fuel dumped in the motor
    2002 Dodge Ram 2500 ctd-more hp than boat
    1972 Nordic jet boat- 396bbc
    "I'd rather be judged by 12 than carried by 6"
    Eastern Iowa
    Quote Originally Posted by TNcumminsguy View Post
    Don't know about you, but a nice Cummins has me .... well you get the idea. And yes the mechanical pump is an easier swap than the electronic controled injection. The mechanical pump should be pretty much a no wire swap. No glow plugs, no injector pump brain.... just crank it and go.
    snow bank
    Quote Originally Posted by Can Am 75 View Post
    Brian
    Holy mosses man. You used a pretty big shovel to dig this one up.
    On your body style truck I would say somewhere around 2 days max.
    On mine I used everything Dodge including the drive shaft that bolted right in. Even the power stearing hose went from one pump to the other. Trans cross member was slid back to the rear holes and drilled new holes for the now rear bolts. Intercooler between rad and grill. Had to cut holes in the rad support for the pipes. Down pipe from turbo fits no problem with no mods. Dodge motor mounts are used but the mount that goes on the motor has to be split and re-angled. I think thats it...?
    Qualified installer....no clue.
    I dont mind the 50mpg with the 323 gear though. 60mph=1400rpm
    Senior Member Hullshot's Avatar
    Dicovery Bay
    thought about this but in a 96 crew.
    High Power Marine Drives & Service
