What does this entail? Suck out the fluid, replace with new then bleed the brakes to get the old fluid out of the lines? Thanks![]()
what I usually do is use a power bleeder- can be as simple as a converted hudson sprayer
(that's what my blue-point one is) or you can use a vacuum style. either way, just don't
let the master go dry- just bleed all 4 corners untill you have nice clear brake fluid coming
out the bleeder screws, and your done!![]()
So basically you are just bleeding the brakes to get fresh fluid at the wheels.![]()
My manual says to use Dot 3. Can I use Dot 4? Is it better? Does it matter?![]()
