2001 GMC Sierra trans
Results 1 to 3 of 3
    Eliminated badluck24/7's Avatar
    Ontario, CA
    Default 2001 GMC Sierra trans
    It's late, I'm tired and need to know what size torx socket I need to remove the shifter linkage bracket so I can get to the bolts on the driver side on a 4L60. Apparently none of mine are the right size.
    WOOP!
    FISHING GOD SUCK MY WAKE's Avatar
    Sep 2009
    directly under the earths sun "now"
    Default re... torx
    Its a 40 torx. blow the dirt out of them cause they round out easy if ya dont get it in all the way, or not square. We replace them with a regular bolt ,, a extra pan bolt works best,, good luck
    Ontario, CA
    Thanks, I'll try again.
    WOOP!
