Trailer hitch sticking
Results 1 to 10 of 10
    Top Deck Bar- P.H., CA millhouse961's Avatar
    Santa Ynez, CA
    Default Trailer hitch sticking
    Does this ever happen to any of you? Every time I go to pull my boat off the ball, it sticks. I have to crank it up high, then get in the truck and move slightly forward or back to get it to pop off. Should I just spray some WD40 on the ball?
    2003 Cobra 270 Razor
    Old Skool Member DILLIGAF's Avatar
    On the road!
    Quote Originally Posted by millhouse961 View Post
    Maybe grease? More than likely it is just a little tight based on pressure. Sometimes but rarely I have to jump on the bumper a bit but it should come off without moving your truck.
    Senior Member bordsmnj's Avatar
    garden grove / emerald cove
    you should have greese on it anyway. -jas
    Quote Originally Posted by Rep. Joe Wilson (R) View Post
    YOU LIE!!!!!
    ..... rivergames's Avatar
    Los Angeles / Parker
    Ha, i have a flattbottom and mine sticks all the time. I noticed its almost impossible for me seperate the two if im on a hill or i need to jacknife the boat into a tight spot. then i just pull the pin on my reciver and drive forward until the hitch slides off my truck.
    Colts fan & Stoker owner RitcheyRch's Avatar
    Santa Clarita Valley
    Grease on it or get one of those greaseless balls.
    http://www.pplmotorhomes.com/parts/r...greaseless.htm
    www.facebook.com/RitcheyRch
    "I didn't pay them for sex, I paid them to leave"
    Charlie Sheen
    Life is all about ass, you're either covering it, hauling it, laughing it off, kicking it, kissing it, busting it, trying to get a piece of it, or behaving like one.
    Formerly CMac Premonition's Avatar
    Phx
    Grease is a must, but I also put the E brake on after backing to keep as nuatral pressure as possible. If you pull through, you may try backing a bit then E brake.
    http://i105.photobucket.com/albums/m240/cmacci/Signature-Avatar.jpg
    Marine Specialist Andy01's Avatar
    Grease, then after you back the boat into it's spot just pull forward a hair. If you are putting tire blocks in, then put the blocks in and pull forward a hair, this letting the tongue come out a bit and taking the pressure off of the rear side of the ball.
    Andy
    The Right Coast/SE-PA
    Thumbs up
    Quote Originally Posted by Andy01 View Post
    Andy
    Yep, that's my move w/grease on the ball too
    The Pool Bitch phebus's Avatar
    Lake Havasu City, AZ
    I used to have that problem, but if you're on flat ground after stopping the tow vehicle, put in in neutral and let it set with the brake off before setting the parking brake and putting it in park. It will allow the pressure to be taken off the tongue.
    Santa Ynez, CA
    Greased up the ball yesterday and worked like a charm. Slid on and off like a......well, a greased ball! Thanks
