Duplicolor Metalcast paint
Results 1 to 11 of 11
    SoCal
    Default Duplicolor Metalcast paint
    Has anyone tried this stuff yet? was thinking about trying it on a few little pieces, bezels, thru hull overboards...
    Looking at some of the youtube stuff that guy's have posted looks pretty good and inexpensive.
    The difference between genius and stupidity...is that genius has its limits...
    2halletts@gmail.com
    1989 Bezer Mango Maddness
    1988 Hallett Vector
    1975 Hallett Barron Sprint (sold)
    2006 Corvette Z06 (sold)
    Junior Member 69 AquaCraft's Avatar
    Jan 2010
    Clear Lake, ca.
    Default duplicolor
    Great stuff but has no strength to it. Kinda like laquer paint. Use the basecoat and finish with clear and it looks really good. Just don't hit it with anything. I used it on my old turnbuckles ( before I replaced everything with a down peddle setup). I am not sure the picture will show it.
    Try it, you can always take it off.
    John Thompson
    An old guy with an old boat
    SoCal
    Cool, thanks. I think I will try it. A lot of powder coat/anodizing is not in the budget this year. Like you said, "you can always take it off".
    2halletts@gmail.com
    1988 Hallett Vector
    Senior Member raysoninoz's Avatar
    Western Sydney NSW AUSTRALIA
    I've used this also and found it pretty good. I've used it over polished alloy which came up good. I have also used the basecoat but MY preference is to polish the metal first.
    On both occasions I have then applied POR 15 (clear) this stuff was designed as a clear coating for wheels. It's great! Does not yellow, sets HARD but seems to have some 'give' and gas & other chemicals don't seem to affect it
    Just my 02c for what it's worth
    Mediocrity is NOT an option...
    SoCal
    I was tinckering around with this stuff the last couple of day, had some free time and look how it turned out...
    might look into some clear coat, this stuff seems a little weak.
    2halletts@gmail.com
    1988 Hallett Vector
    member
    Nov 2008
    Quote Originally Posted by BASS LAKE BARRON SPRINT View Post
    Looks good, nice bowl bolts.
    Frozen Hoser Airpacker's Avatar
    Aurora Ont.
    As mentioned, its pretty easy to mar but, burried under 5 coats of clear, its holding up pretty well. I used the base coat and then several coats of the emerald green, tossed on a coat of the duli color metal effex ( micro flake ) and then cleared the hell out of it.
ID:	68299   Click image for larger version.
ID:	68300   Click image for larger version.
    Quote Originally Posted by Airpacker View Post
    I haven't seen the green before, only red, blue & purple.
    Certainly looks different though
    Aurora Ont.
    Quote Originally Posted by raysoninoz View Post
    Well, its a white boat with purple and green graphics. I checker plated the entire engine compartment. snow white powder coat on all the sides, transom and seat back, Metal Cast Purple on the floors so it only seemed fitting to use green on the motor.
    This pic was after thr first heavy coat of clear before colour sanding and clearing 4 more times.
    SoCal
    looks awesome! I'm getting a little addicted to this "rattle can" stuff.
    2halletts@gmail.com
    1988 Hallett Vector
    Somewhere between Paso & L.A.
    the red and blue work real good for touching up those sun faded "pink & blue" AN fittings! (JUST MAKE SURE U USE THE POR 15 CLEAR!)
