I have a stock power steering pump and installed a full hydraulic system with twin rams. At idle (700-850 rpm) the wheel sometimes turns like a 1968 chevelle at a stoplight... is there a high volume pump i should have put on?
thanks...
thanks...
..Stroke it,
......Blow it,
.........Get it Wet...
HTM
High Torque Marine
Yes the pullies are stock,I changed all the fluid when i installed the system...your probably right the pump is older (was in my 92 baja)thanks GT...
..Stroke it,
......Blow it,
HTM
High Torque Marine
Don't you have to drill out an orifice in the pump to increase flow???
