07 Merc 496 HO how to purge fuel lines? or
Will leaving off gas cap get air in the fuel line to need to have that purged? and or will running out of gas do the same thing? had both things happen and a mechanic had to purge the fuel lines-a few days later I ran to E on a tank and the boat did the same thing would not start after switching tanks but using some starting fluid I got it to start and run ok-how can I purge the line like the mechanics do if this happens again?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
