Glass Tanks ?
Results 1 to 6 of 6
Glass Tanks ?
    Bullhead City, AZ
    Default Glass Tanks ?
    I am wondering what type of Resin was used on Fiber Glass gas tanks ? I have a repair that needs to be done to a plastic fuel cell. It is a cell I had in my boat for the '07 Parker 300, it slipped and touched the alt pulley. I am thinking of using Sea Goin Poxy Putty and then sealing it with resin. It will be going back into the steel can after repair. I have heard of the plasic welding deal but I have not had any luck with it. Does anyone have any other Ideas ?
    Jim
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Sacramento area
    Marine tex
    Bullhead City, AZ
    Quote Originally Posted by schick View Post
    Marine tex
    Will that stick/adhere to the plastic of a used fuel cell, after a little research I found out Sea Goin Poxy Putty will not ?
    Jim & Amanda Rich
    CJ 72 & 53c
    New Jersey
    Jim,
    I believe that Marine Tex is a similar to the Sea Goin Poxy Putty and therefore would not stick/work.
    For me there is too much at stake to risk using a patched fuel container in a boat, even an open boat. Leaks could cause a catastrophic event. But that is me.
    There are "epoxy" type products available that are compatible with different plastics. In order to patch the plastic, you need determin the compound (ABS, Polyethylene, etc)and then find an epoxy that is compatible. If your plastic is the same as an automotive product (bumper, etc) you might find what you need at an auto store. I have successfully used some of this epoxy for plastic with fiberglass mat to repair a Thule roof top carrier.
    Good luck.
    Doug
    Bullhead City, AZ
    Doug,
    This cell is going in my 8100 Desert race truck. It will be outside and be in a steel can. The truck is not going to be raced just used as a Pre Runner now.
    Thanks and Happy New Year
    Jim
    Jim & Amanda Rich
    CJ 72 & 53c
    Default Tank repair
    I would check with the tank manufacturer, to find out the material used. The plastic water tank in my camper from the '60s, I repaired it with melted plastic dripped on the crack.
    HARLAN ORRIN
