dual fuel tank wiring diagram/ help
Page 1 of 2 12 LastLast
Results 1 to 14 of 27
    Sacramento Ca.
    Default dual fuel tank wiring diagram/ help
    My buddy and i are having trouble tracing down trouble with the fuel systems wiring.. We know the gauge works but unsure if the senders are any good. we traced back all wires and found some that have been cut and just dont make any sense. Is there a way to test the sending unit while in the tank or must it be removed... And does anyone have a simple giagram of how to run wiring for dual tanks to a single gauge... For some reason one tank feeds faster than the other so a switch needs to be wired in to check level of both tanks..
    A switch has been pre wired into the boat from past owner but from the looks of it, its never worked..
    UMPBA.ORG sleekcrafter's Avatar
    Quote Originally Posted by matt1840 View Post
    The sender should read about 30 ohm empty, and near zero ohms full. You only need to switch the sender wire between the tanks, be sure the senders are grounded, or they won't work.
    Sacramento Ca.
    Sleek,
    Here is a diagram of what we have. We weeded out alot of useless crap and came up with this. We can switch between senders, but even with the tanks 1/4 full we always get a full reading on the gauge for both tanks and an empty reading in the neutral position. My guess is im switching over a full 12v to the gauge which is giving me this outcome.. Do you see somethin wrong? I dont really see both senders being bad... or maybe??
    I see the problem.... on the guage there is (I) ign, (S) sender, and (G) ground. The (I) goes only to the ignition, the (S) goes from the guage, to the center tap of the switch, and the (G) gets grounded. Now from the switch, your left and right sending unit wires attach to the throws of the switch. There is no need to switch the grounds thru the switch. Hope this helps
    Sacramento Ca.
    oops i did forget to show the wire leading to the ign from the gauge.. but it is there. should i switch it up to a single pole double throw switch??? (3 prongs) sender wire from gauge to center prong on switch and a wire from each center pole on sening unit to each side of switch? i understand that the grounds dont switch just the "hot" wires per each sender.
    possibly draw up a diagram to show just incase im not following you?
    Senior Member bordsmnj's Avatar
    garden grove / emerald cove
    well, it aint pretty but here it is.
    the only reason i can think of to bring a ground to the switch is if it has a light in it. in that case you would bring a hot from the switch for your dash lights over to it. that part isn't shown here.-jas
    Quote Originally Posted by Rep. Joe Wilson (R) View Post
    YOU LIE!!!!!
    Sacramento Ca.
    At this moment in time im pretty damn sure ive got the wrong switch for the job. im gonna try a single pole dual throw tomrrow and see what i come up with. Not to mention test the senders.
    It's good to be alive
    Lake Havasu
    Your DPDT switch will work fine, just use one side (pole) to act as SPDT. Wire like that funky hand sketch
    Sacramento Ca.
    after researching how a sender and fuel gauge work together it clicked in my head. I knew exactly what was wrong. And yes the hand drawn diagream was correct. No power or ground are needed to the switch unless it is a lighted switch.
    here is what i switched up and works just fine now, did have to pull the senders to get them unstuck as they were stuck in the empty position. Everything works just fine and can read levels of both tanks.
    Thanks for the help.
    cool.
    so, what did you draw that little scetch with? kinda cool. being an electrician i should have something like that,lol.
    YOU LIE!!!!!
    Senior Member BLOWN HOWARD's Avatar
    yeah what program is that
  13. #12
    Sacramento Ca.
    check it out its a top secret program...
    come a little closer :whispers: microsoft paint!
    startmenu click accessories and the paint icon just save as .jpg and your good to go.
    SHOCKER!
  14. #13
    SHOCKER!
    last I read about microsoft basic programs.. they are only used
    for less than 5% of what they are capable of doing.
  15. #14
    Lexington, KY
    Question
    I'm not an electrician, and am basically clueless about wiring and electrical stuff. So my question is, what is a single pole double throw switch? Is it a two position (on-off) type switch, or a two position (on-on) switch, or is it nether of these and something completely different like a three position switch? Can I see some pictures, and where can I get them?
    I am getting ready to do my fuel system and have do idea how to it. I am going to start a new thread on the entire fuel system rigging; plumbing, wiring, filters, pumps, all the stuff that goes into rigging a proper fuel system for dual tanks.
    Sorry about the thread jack Matt.
    Thank you.
    HJ
