I am looking at adding some trim tabs for my 24 foot Ultra Stealth. I am running a stock 496 MAg HO, Bravo 1 X drive with a Bravo 1 26 prop in the low to mid 70's (72/74). For my application I am just trying to get rid of some chine walk and stabilize the ride of the boat at higher speeds. Any information would help.
My questions are as follows:
1) Which type of trim tabs should I look towards, Dana Marine, Eddie Marine or Bennett?
2) Will the Sport type tabs that each of these companies make work?
3) What size?
4) The fourth question is more of an installation question. I have seen some of the trim tabs on boats run with the angle of the vee bottom and some run flat (horizontal) across the back and not with the V of the bottom. What is the difference? Which would work best for my situation?
