[Pics] Gale Banks intercooler
Results 1 to 5 of 5
    Default Gale Banks intercooler
    Purchased a Gale Banks intercooler sometime back, has seen a few discussions regarding what the intercooler cores look like, co decided in weekend to pull it a part and check gaskets, and see what IC cores looed myself
    In doing so polished the IC casing up, and soaked the IC cores in a cleaner/boiling water. So for those that are interested took some pics
    Not sure how different the Richard Lee intercooler cores are to the Gale Banks, perhaps someone can help mne with that?
    Gaskets are in reasonable cond, imagine I will just use a little silicon to help seal.
    coes seem to be in excellent cond, not usre whether its worth getting them pressure tested?
    good site lots of information, have learned a lot so far Thanks
    Attachment 0
    Default PFM Vs Gale Banks Intercooler cores
    sorry meant to say what is the difference between PFM and Gale Banks IC cores, I note PFM intercooler has 2 hoses feeding each IC core (2x2), and Gale Banks has 1 feeding IC core
    any difference in efficieny here?
    Banks has one-3/4" inlet & two-1/2" outlet,PFM two 1/2" inlet & two-1/2" oulet. No difference in efficenicy.Those are the good Harrison cores,you should make a plate for the front & pressure check them or takem to a good radaitor shop, that can remove the rear tank, clean them out & reinstall the tank
    Default pressure test
    Hi
    Thanks for your comments, i pressure tested the radiators in weekend to 60lb/in, so all good, and assumbled intercooler again
    cheers
    sacramento
    Quote Originally Posted by bjf66 View Post
    Hi
    cheers
    i don't think i would have used silicone with the rubber gasket, from what iv'e been told & seen ,they will leak if you do that.
    not 100% sure . anybody?
