winter sleekcraft project
Page 1 of 6 1234 ... LastLast
Results 1 to 14 of 75
    Oct 2011
    Default winter sleekcraft project
    Starting build thread, should be fun winter. Ours is too long up here. Pulled motor last weekend, already disassembled it. Rebuilding motor from stock 320hp to around 450-460hp. Boat went 60 on gps with "A" impeller in stock form. Not bad. After motor the paint and interior are next. Should be busy winter.
    Oct 2011
    Motor apart. Looked really good. Picked up set of D0ve heads. Going to be redoing those too. Mild port work, valves, springs. etc. While parts are on the way, took carb apart and rebuilding it right now. Parts arrive tomorow for it. Thinking powder coating some of the main body or bowls, anyone have any luck with this?
    Oct 2011
    Picked up block today, assembly planned for the weekend
    Oct 2011
    Short block ready for assembly just waiting on rings now. Got intake today
    Oct 2011
    Assembled short block, have to post up some pics. Porting heads next. And a whole lot of polishing and cleaning left.
    Oct 2011
    Carb rebuilt. First time trying the powder coat.
    Oct 2011
    Another pic of matte black powder coat carb. Worked out well. Cheap way to really put some bling on it. Lol
    A legend to the DNR vdrive502's Avatar
    Lake Hallie,WI
    Yup it does look good the local carb shop up by me Big's performance uses imron paint to coat the carbs and bake it in the oven then call it "Platni-Blast" finish.
    Sep 2008
    OC, CA
    Nice build. What pistons are you going with?
    Oct 2011
    Since everything was so unused (low hours) on factory parts I reused factory pistons,rods, and crank. Light hone on block to deglaze. Thinking factory cast piston should be ok with 450 hp. Only 9.5-1 ratio, no boost or blower.
    Oct 2011
    Scored some valve covers this week, 80 bucks on craigslist. Now just need to find MSD this cheap. Lol
  13. #12
    Oct 2011
    Timing chain issue pretty easy with the comp cams stuff.
  14. #13
    Oct 2011
    Crank and pistons installed. Timing chain degreed. Oil pan and timing cover next
ID:	142568   Click image for larger version.
  15. #14
    Oct 2011
    Short block done. Next the d0ve head porting and new bigger valve project.
