[Question] Prop shafts
Results 1 to 9 of 9
Prop shafts
    Can't cure stupid 1Homeblown's Avatar
    Sep 2008
    Torrance, Ca.
    Default Prop shafts
    Is there an easy way to find out what material my prop-shaft(s) are made of? Whether its stainless, aquamet, or Monel?
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    The Monel is usually darker in color. The stainless might have more rust on it than the Aquamet but as to being accurate it is anyone's guess. I am sure that there are some experts here, so I hope that they show up and help you out...
    Steve
    Sep 2008
    Torrance, Ca.
    Quote Originally Posted by Roaddogg 4040 View Post
    Steve
    Thanks for the reply. I have three shafts that I cant use. I'd like to know what I have before I get rid of them.
    Thanks again.
    Senior Member Pm/pe122's Avatar
    Oct 2010
    i believe a magnet will not stick to stainless , you may be able to eliminate one of the metals that way !
    Sep 2008
    Torrance, Ca.
    I guess my question is will a magnet stick to aquamet or Monel?
    Precision Craft Marine
    Napa, Ca
    Monel is darker in color, but Aqua-met comes in different grades. most common is 17, 19, and 22. we only use 19 and 22. I use 19 for up to 450 hp, and 22 for everything else. some venders sell 19 as 22, and they double their profits, and you lose your prop. As a dealer, even I have been sent the wrong material, but we know if they are the real deal when we cut the keyway in the shaft. And don't fall for that by the inch stuff. They hit my door step in 96" lenths. you can rockwell test them.
    Meridian, Idaho
    Default j shelfo
    can you get k monel prop shafts
    Napa, Ca
    sorry, I do not. K- monel is good material, But the aq-22 is more compatible with the prop material, at least for us, with todays propellers. If you get real aq-22, and the props are lapped correctly, and the prop keys are made correctly, you shouldn't have any problems. the biggest problem with this is getting the tapers to match, or some prop manufacturers hubs hang off the taper too far. The taper in the prop has to be perfect.
    Oct 2010
    joe im gonna put a call into diez this morning , then to you !, see if i can figure this out ,
