Zoomies on stack injection? - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 29 to 42 of 49
  1. #29
    Senior Member ps12's Avatar
    Apr 2009
    Temecula ca.
    Quote Originally Posted by flatrat View Post
    July 2009 269.jpg (96.8 KB)
    Seems a little flatter on the top now than with the Bassetts before
    Nice looking ride, you guy's are dealing with density altitude aswell, how about a pic of the fuel surge tank, i need to build one... Thanks for the participation.. Scott
    Senior Member DaveSammons's Avatar
    Carlsbad, California/ Marina Manor, Parker, Arizona
    Dave, thanks for posting up numbers instead of some of the theories that have been thrown around (including myself in the throwing). Numbers produced in a careful dyno session always trump what I "wanted" the dyno to tell me. I will refrain from questioning the details as the trends there are close enough to answer my basic questions. Being that I can't shut my mouth I will reiterate what you said as the size of the pipes are important.
    If you don't mind we asking, did you play with different diameters and lengths on the dyno?
    Paul
    Yes...pretty interesting stuff, info is gonna cost you though...Might have to get your Pop involved
    Quote Originally Posted by ps12 View Post
    Nice stuff guy's, and special thanks to Professor Sammons, that is a Great share on your part, keep them coming and I'll let you know what we find when we start comparing the old known performance numbers with the headers to the zoomies..... Thanks Scott
    From experience...I would recommend, starting with a 2 inch diameter pipe...sounds small, but seems to work best on unblown engines with less than 850hp.
    I have run them on 1000-1100hp Blown Alky engines with little or no difference in ET or MPH when switched out to larger diameter pipes.
  4. #31
    Members only MAXIMUS's Avatar
    Close by
    Quote Originally Posted by DaveSammons View Post
    Well you can take the following for what it is...
    I have run Zoomies on unblown engines for years...And I have done it knowing just about exactly what it costs me.
    Now granted some engines may need to be tuned different, some cams/heads may react different. But in drag racing as long as it ran the number, I liked them better...easier to work on, sound bitchin, look bitchin...AND I have never had a problem with losing the amount of horsepower claimed by some...FYI...(tube size has alot to do with it)
    Unlike most others, I am able to dyno without mufflers...to run the exhaust exactly how it will be run in the boat.
    I have been reluctant to post the following, but figured it was time to let those who have questions in on at least what I have learned...so like it or not...I think there will be some information learned...stuff here that even might make the "experts" go HMMMM!
    First up...
    Our example in this case is a pretty staightforward 500 inch BBC, aluminum heads, Roller cam(.785 lift), Nice topend pieces, 13.5 to 1, Hilborn stack injectors with a vertex mag...engine was built to go circle racing...
    These first numbers show where we ended up with the stepped Leach headers that all the monkey see/monkey do boys run on the Sprint Boats these days...
    So we have a maximum HP number of 794.6 at 6800 and the torque peaked at 687 at 5400.
    I really like this format because you can see an average of what the numbers are from 4800 on up. Very handy especially in a sprint boat application.
    Next up 2.25 Zoomies...
    We see our maximum HP came in at 785, but we had to stretch it out to 7100, peak torque pretty close 684 at 5500...but look how the torque numbers change between the 2 on the way up...big advantage to the leach headers...16 ft+ pound of torque on the column average...IMHO Torque is what moves the boat...most would disagree. 14hp on the average...not a ton...
    And just for fun...a 30 year old set of shortened bassetts...
    This can't be! A worn out set of Bassets within 2 HP and under 5 Ft Pds of torque versus a 1500.00 header...HUH?
    Well, if you look at all the numbers(and I hope you all do, cause you can come up with alot of interesting theories) the Leach's are better by a bit and probably worth running(but for the price diff?) versus the Bassetts, but it is interesting in what most people get their heads wrapped around in it terms of overall hp and torque like you would read in an advertisement or one of the Car Comic books, that they are pretty close!! Remember to that the engine was tuned for the Leach's...could there be more hp/torque coaxed out of the thing for the other headers with some tuning??? Maybe???? Love to show ya what a set of Lemons do...But, maybe another time!
    If you think about it the modern unblown dragboat that runs no quicker than 9.00's spends it life with the new deadwater starts in the 6000-7500 range...Maybe more on the low end depending on prop burn, Are the zommies gonna kill that much HP/torque...ya probably couldn't feel it if you had the tune up right...so for a lake boat? I say Zoomie away!!!
    Hope some of this was useful!!!
    Dave
    Grich??? Grich is that you??? Dave you need to spend less time with crusty... seriously...
    "How do you tell Jerry and Rayzor apart at the races? ..............Rayzor is wearing deck shoes, sunglasses, white shirt with gold and black stripped epaulets and a Captain's hat........ Jerry has the camera." GN7
    http://www.gn-racing.com/
    http://site.enduro300.com/Home_Page.php
  5. #32
    It"s strange you say that...just last week I made Tom Farner drive me to the parts store and told VanBeenan if he wanted me to go to lunch, he'd have to buy...and I find myself wearing sweatpants alot more often...You could be right, my friend
  6. #33
    Senior Member mdsheppie's Avatar
    Jun 2010
    Michigan,The State Of Confusion
    (insert comment here) well there goes the neighborhood
    Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
  7. #34
    Sep 2011
    Ventura County, CA
    First up...
    Dave
    Dave, what a fantastic post! It's so great to have some actual numbers to work off of. This really cuts through all the guesswork. It's interesting how close the Zoomies are to the headers. At 6000 rpm, they are within 1.5 hp of the Leach's. They lose slightly more above that, but as you mentioned, the engine wasn't tuned for the Zoomies. Even so, the Zoomies didn't lose much.
    I agree, Zoomie away.
    Michael
  8. #35
    gn7 is online now
    When you ask more questions than you answer, and any question is followed by 3rd degree, then I will worry about you.
    Buy the way, the last 2 times I had lunch with Grumpy, HE BOUGHT! So its my guess he doesn't much care for you to come around and uses that as a deterant, or you owe him money.
    LINK:GN-RACING.COM
  9. #36
    Close by
    Please not while I am drinking coffee... I now have to change my shirt!
  10. #37
    Close by
    Try going to lunch 30 & 40 times. He bought for me the first 2 times as well!
  11. #38
    Upstanding Member Sharp Shooter's Avatar
    The Parking lot
    Quit making fun of his socks and maybe you'd fair a little better.
  12. #39
    gn7 is online now
    Ben, its time to come to terms with your relationship with Gritch. You have more money, and he doesn't really like you.
    Just say'n
    LINK:GN-RACING.COM
  13. #40
    Close by
    Ben, its time to come to terms with your relationship with Gritch. You have no more money, and he doesn't really like you.
    Just say'n
    Thanks for stating the obivous... And there is no T in Grich...
  14. #41
    gn7 is online now
    My mistake. I keep forgetting. But there is an "N" in GriNch. And the name fits
    LINK:GN-RACING.COM
  15. #42
    Overdrawn flatrat's Avatar
    Terlingua,TX.
    • July 2009 475.jpg (100.6 KB)
    • PICT0072.jpg (97.0 KB)
    • Copy of PICT0071.jpg (100.8 KB)
    • Scott lots of air here in the trees,altitude is 2700 ft.Hope this helps
Name:	July 2009 475.jpg
ID:	157031   Click image for larger version.
ID:	157032   Click image for larger version.
Name:	Copy of PICT0071.jpg
