Prop Strut Needed...
Results 1 to 10 of 10
    Lake Arrowhead
    Default Prop Strut Needed...
    I managed to bend my 10* prop strut on my Spectra. I would like to replace it with an identical match to speed up the re-installation time. I searched the Parts Swap and didn't see anything that matched what I have now.
    Existing strut base is 8" long by x 4.50" wide. Barrel is also 8" long. It has a 6 bolt pattern. The spread from center to center of the farthest holes is right at 6.50 inches. Drop is 8.00"
    Thanks!
    Jeff
ID:	157184   Click image for larger version.
ID:	157185   Click image for larger version.
ID:	157186   Click image for larger version.
    Senior Member LiquidDan's Avatar
    Send to Barber Welding in Bell Gardens Ca
    Call Kel at 562 928-2570
    Lake Arrowhead
    I will give them a buzz tomorrow. I thought about trying to straighten this one myself... I would still like to pick up another.
    Thanks!
    Senior Member CampbellCarl's Avatar
    Whittier, CA & Katherine Landing
    X2 on Barber, they are V-drive people to boot.
    They did my new strut for the Howard 24'
    CC
    Originally Posted by Rattle Can Lou
    Again, if I came across as a v-drive snob..I apologize,
    Mike
    Lake Arrowhead
    Carl... what sort of strut did you have built? A buddy made a nice strut for his Schiada... I might go the custom route but time is ticking away... kinda wanted to be on the lake today but that ain't gonna happen. ;(
    Jeff
    Quote Originally Posted by AlohaJeff View Post
    Jeff
    Duplicate of original strut (mine broke into two pieces). Similar to yours, I think both the barrel is longer and the mounting plate as well.
    Mine was made because of this......
ID:	157195   Click image for larger version.
    Mike
    Senior Member Hi Tech Marine's Avatar
    Simi Valley
    I also build Custom Struts. Mild steel $750, 4130 stress relieved $1500. Turnaround time is less than 2 weeks.
    Lake Arrowhead
    Can't do steel... the boat sits in the water for days... my almost new steel prop was destroyed in one season. Arrowhead water is very hard on boats. It will either have to be stainless or bronze.
    Aloha
    Placentia, CA
    PM sent.
    steveo143 AKA DiMarco 21 II
    RIP Davey B and Denis
    Lake Arrowhead
    Still looking for a good used one... with all of the other stuff going on I'd rather not have to spend $750-1000 on a new strut right now. The twist and bend in the current one isn't looking too good. I've also been told I'd be crazy to not change the strut design if I decide to get a new strut built. Right now the kids just want to get back out on the boat.
    Plate Dimensions... 8" x 4.5"
    Drop = 8"
    Barrel = 8"
    Degree = 10*
    Thanks guys!
    Jeff
