shaft log seal
Results 1 to 5 of 5
shaft log seal
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    Default shaft log seal
    Had a chance to launch the boat and walk around it while it was floating. I noticed that the shaft log seal was leaking. Not bad just a drop every 5-10 seconds. Is this normal? If not what is the best fix?
    Senior Member LiquidDan's Avatar
    Quote Originally Posted by steele211 View Post
    I make these and sell them for $55...1", 1 1/8" and 1 1/4"....lighter than the heavy brass housings with a loose fitting bore that wears out just the top of the seal lip
Name:	Canyon Shaft Log Seals.jpg
    Shoot a little grease to it before you go out .
    Nov 2008
    Kingsburg,CA
    What grease is the good stuff? Newbie question
    Senior Member mdsheppie's Avatar
    Jun 2010
    Michigan,The State Of Confusion
    wheel bearing grease red or blue...No lithium ,
