Pictures needed - steering
Results 1 to 12 of 12
    Default Pictures needed - steering
    The boat I have came in pieces with parts all jumbled. Need pics of cable steering pulley setups - I think I am missing some pulleys and have a few pieces I can figure out. Could also use pics of steering column with the gear placement for the chain etc.
    Thanks.
    Atlantic Beach, FL
    Here's some from the quadrant
Name:	Steering Gear 001.jpg
ID:	158394Click image for larger version.
Name:	Steering Gear 009.jpg
ID:	158395Click image for larger version.
Name:	Steering Gear 007.jpg
ID:	158396Click image for larger version.
Name:	Steering Gear 006.jpg
ID:	158397Click image for larger version.
Name:	Steering Gear 003.jpg
    Default Pics
    Thanks - so do the cables only run down one side?
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    Quote Originally Posted by Community View Post
    YES, one side only...
    Steve
    gn7 is online now
    Quote Originally Posted by Roaddogg 4040 View Post
    Steve
    thats true if the boat was equiped with a quadrant, and single unjacked cable. Some boats, even V-drives had single and dual cable tiller steering.
    community, it might help if you laid out all the parts to the sterring you have on the floor and photographed them. Then people on here could post pics how each part is installed in the boat.
    LINK:GN-RACING.COM
    I guess that I should have said that on his boat the cables run down one side only, not every boat, but most v drives use the cables on one side.
    Steve
    Senior Member f_inscreenname's Avatar
    Pasadena, Maryland
    Some ref pixs from the Bies project. Hope it helps.
    It's not about being noticed, it's about being remembered. ResurrectionMarine.com
    19’ of rolling thunder chasing the wind. 24’ Of Rolling Thunder, Chasing The Wind, Catching It, Whoppin’ It’s Ass, Then Saying, “Now B!+ch, Go Make Me A Sandwich! SuperNova19.com / SuperNova24.com
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Steve
    And further, it is different pulley configuration and types depending on whether inside stringer or outside stringer...
    I guess that I should of gotten a micrometer out for this answer. They also have different sizes of cable... and different sizes of bolts too...
    Steve
    Blog Entries
    24
    Not at all Steve. The guy asked about different pulley setups. The pulleys for inside vs outside stringer are entirely different on the passenger side of the boat. Thought that was useful to his question.
    ..... rivergames's Avatar
    Los Angeles / Parker
    Hey Gary, If you want to come check out the steering on my schiada this weekend, you are more then welcome to. I through on most of the pulley yesterday and will have the steering wrapped up by Friday
    Life is too short for a slow boat
    Quote Originally Posted by Tor View Post
    Balls drop, balls grow, and balls eventually get placed into a woman's purse. That's usually when the hard passes in front of Fox's stop and the busting of youth's balls start
  13. #12
    THE LEGEND Mouzer's Avatar
    corona ca
    he got the parts that were pulled from the boat......if you want i will swing by and check it out its down the street at the shop....
    FUGITIVE RECOVERY/BODY GUARD/PRIVATE INVESTIGATION/CHEATING SPOUSE/STALKER
