what manufactor is this
Page 1 of 3 123 LastLast
Results 1 to 14 of 36
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    Default what manufactor is this
    pre 70 im told also told is a sanger
ID:	161583   Click image for larger version.
    Lookout I'm Crankin it Baby Rattle Can Lou's Avatar
    Boise, Idaho
    No Sanger....
    Upstanding Member Sharp Shooter's Avatar
    The Parking lot
    How about a bottom pic from the front looking back. It may be a Hondo sprint. Definately not pre 73.
    Menifee
    Pic of the bottom would help and also a side shot. At this point I would say Hondo as well.
    Keith...
    Monstrous
    Jan 2010
    Corona del Mar, Ca.
    Hondo. The rudder looks off center. Hondo did this to remove the prop shaft without removing the rudder. JMHO
    Senior Member Factory1's Avatar
    Quote Originally Posted by Sharp Shooter View Post
    X2 on the Hondo sprint, looks like there could be some gullwing shape happening on the plates...
    Jul 2009
    rio linda calif
    couple more pics
ID:	161611   Click image for larger version.
ID:	161612   Click image for larger version.
ID:	161613   Click image for larger version.
ID:	161614   Click image for larger version.
    Jul 2009
    rio linda calif
    one more
    Senior Member Retired Flatbottom Racer's Avatar
    Tulsa, Ok
    I don't think it's a Hondo. Where the rail comes around the edge of the deck .....at the nose the radius is wide, like a Cole, Dimarco & Canyon. Hondo has a tighter radius at the nose. Nothing in that boat looks like typical Hondo hardware. It apears that it doesn't even have a blast plate.
    My guess is that the T deck may have been cut in an older boat. I've seen lots of them done in the past. The deck shot from the rear makes me think of an early Kurtis. Just my 2 cents worth....
    Jul 2009
    rio linda calif
    Quote Originally Posted by Retired Flatbottom Racer View Post
    what is a blast plate= i am not a v-drive guy but a jet guy
    Early Kurtis ! Not pre 70 tho !
  13. #12
    The Parking lot
    I think you're right Bill! It's definaty not a sprint. These new pictures are much better.
  14. #13
    Menifee
    Not sure what it is now but I do know it looks EXPENSIVE!!!
    $20,000 before it hits the water........
    Keith...
  15. #14
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Quote Originally Posted by justsquirtin View Post
    The blast plate is an alum or stainless plate that extends from the strut to the cav plate above the prop to keep the 'prop blast' from damaging the hull.
    You thinking about goin v-driving???
