Originally Posted by
infotraker
Went thru all of the connections. Cleaned all grounding connections. Found 1 loose wire on a lug off the dead man switch, it came uncrimped. I could pull it out of the lug. Hopefully this is the problem as if the wire pulled a little out while running the ignition would quit.
The question is if the wire was barely connected could the tach act up a little before the engine quit ? The engine quit maybe 30 seconds after the tach went wild the first time and the tach went wild and the engine quit immediately the second time.
I guess the only way to prove it is fixed s to get on the lake, don't want to be towed again if it quits again. It runs fine on the trailer, ran it for several minutes with water but any longer and the headers get really hot without water.
Going to CFW next week, lots of tow boats but want it to run without any problems this year.
