gears for elsinore
Results 1 to 14 of 14
gears for elsinore
    Default gears for elsinore
    I ran Firebird in may and was turning 6900 Rpm, 104mph best time of 10:22 with 15's in the v-drive. Is elsinore water any faster. Should I try 12's to have a better shot at 10:00's. I think the motor would like a few more r's. Prop is a menkens 11 1/4 x16. Boat is a sanger runner bottom.
    armandshammer
    Mohave Valley/Quartzsite
    I personally believe the water is very similar. What's your motor combo? I would do some T and T on Friday and run your current set up first and then go from there. How did the boat leave with the15s? Was it still pulling the 15s at Fireturd? You should have plenty of time to change gears. Pick your poison and have fun!!!
    Special Thanks to:
    Nelson Speed & Marine
    www.aholeregistry.com
    J.J. @ Beaver Fab
    Performance Boat Candy
    the motor is a 496. I am trying to get a lot closer to 10 flat as I know there are several boats in that bracket that are capable of running on the number.
    armandshammer
    Quote Originally Posted by Desperado View Post
    Give it a shot.. Can't hurt anything.. Just by the way things have been going, make sure the big gear goes on top.. I've seen/heard people doing that more in the last month than I have in my short life.. Good luck this weekend!!!
    Special Thanks to:
    J.J. @ Beaver Fab
    Senior Member liquid addiction's Avatar
    Hell ya! Put the 12s in there. Stick you a set 9s in the tool box just in case. It'll be ahhright!
    Quote Originally Posted by stix818 View Post
    who blabbed? But that was last year, that's all behind me now! lol
    Wind her on up , hey , Ralph. When we gonna see ya at the races again?
    armandshammer
    12s would probably help. Also, an 11 1/4 is a big prop. I'd try something around 11 or even 10 7/8" diameter. Will help you early in the pass and also make it drive a bit easier. Wish were were gonna be there....Good luck.
    I was thinking the prop could use a little trim also, I am supposed to report rpms at a couple seconds into the run and Harold will make the call on that.
    armandshammer
    I was thinking the same thing initially David but failed to mention it. I'm becoming a fan of the smaller diameters!!!
    Special Thanks to:
    J.J. @ Beaver Fab
    You mentioned Firebird in May, are you located in Phoenix? Where you at in your journey?
    Special Thanks to:
    J.J. @ Beaver Fab
    No time soon Armand. Got alot of stuff going on with work for awhile. I also broke my heap last time out. I got a brand new short block sitting on the shelf but no time or $ to finish right now. Good luck to you this weekend. Be safe.
  13. #12
    just down the road in El Cajon. Be up at elsinore afternoon friday
    armandshammer
  14. #13
    Well good luck!!!!
    Special Thanks to:
    J.J. @ Beaver Fab
  15. #14
    Senior Member Ripple Rider's Avatar
    Jan 2010
    Reno, Nv
    I'd suggest making only one change at a time. Prop or gears.
