Hi all,
Had the Stevens out for the first time today. (busted my hump for days getting it ready). Have a few questions to make it run the way I'd like.
1- The shaft log seems to be leaking too much. It has a grease nipple in it. Is this to pack with grease to slow the leak? From other boats it's known to have a bit of water come in. Is this the same case with this set up? (I didn't have a grease gun on board when on the lake...) See pic below...
2- When I hammer the throttle, it sounds/feels like the prop is slipping, or spinning a bit. Do I need a more aggressive pitch? I put a 3 blade on (and damn if I didn't look at the numbers first!) but I can get them in the morning. I have another 3 blade 12x16, but looks like the one I have on now is bigger...
3- When cruising (guessing 30 mph) there is a good hump of water off the rear of the boat. Can I adjust the cav plate to calm this hump down a bit? I will be pulling skiers and am thinking this will be intimidating.
pics coming up...
thanks!
LinkBack URL
About LinkBacks
... You might try at least 50' and you'll find you can gain more speed on the cross-over for some "air" across the wake. Also, it makes the skiers arc wider for a longer--quieter--ride.
