gear question
Results 1 to 9 of 9
gear question
    WHITTIER CA
    Default gear question
    Last weekend i was at urvine and boat ran bitchen and now that the motor is dialed in and i finally understand how to drive it, lol , i believe i need more gear and then will fine toon with a prop change as the one thats on it i cant even tell what it is.
    Boat - is a 1985 eagle b bottom(similar to a beismeyer bottom
    motor is a 500ci cheverolet with 8 lbs a boost (aprox 750)
    gears are belived to be 18s
    current rpms is 8300 on the tattle tale jones tach
    current mile per hour is 95 per daves radar gun (seems faster lol)
    i soke to menkins and they have a set of 30s for me and i just wanted some input to see if that seemed like the right step or if im gonna over shoot my mark( 7200 red line)
    thanks for all your help
    Placentia, CA
    Sounds about right if you want to drop your rpms. I have the same boat, the Stacey's PS303, and it had 29's in it.
    steveo143 AKA DiMarco 21 II
    RIP Davey B and Denis
    Senior Member racerick784's Avatar
    Jan 2012
    ROSEVILLE CA.
    This is only based what RPM I see. I don't know what prop you have. In my opinion 30's might make it lazy on your ET. I would suggest 25's . If your set-up is good and your power is what you say. You should ET good and run 112 to 120 MPH if you have a good prop. P.M. me if you have any questions. Good Luck, RACERICK
    Hudson, Wisconsin
    Quote Originally Posted by racerick784 View Post
    I agree with Rick, 22-25% gear......especially if you have a 16 pitch prop (more than likely). If you don't have a 16 pitch, you should! Jocko
    WHITTIER CA
    Thank you for the help guys, i did decide to go with 30s from menkins cause thats what he had right now, and now im a bit worried about it lol. If its turns out lazy i guess i will just have to put a tad bit more boost to her. Once i try it out i will fine tune with a prop. Thank you all very much
    Placentia, CA
    If your not racing it, you should be fine. A little more boost is nice to have available! The Stacey's boat was slow off the turns due to the higher gear, but then I'm not sure they ever got the injected motor to run correctly either. I have ditched the injection and am going carbed on E-85 and a 15 gear. My son wants to race the Nos 80 and the 95 class if enough boats get built.
    Newbury Park, Ca/Bullhead City Az
    Default Yes....
    Quote Originally Posted by steveo143 View Post
    Yes, they did get the "hat" dialed in. Boat ran good down the straights PS competition.....
    Ray
    LOUD BOATS SAVE LIVES
    3 OPEN flatbottom APBA seasons left.....Let's RACE
    HONK if you voted for obama........
    It's that button in the middle of the steering wheel........
    Placentia, CA
    Ray
    I am saving the hat for a K motor in the future!
    Aug 2011
    I have a set of 25% that I need to get rid of.
