Self Bailers.
Results 1 to 13 of 13
Self Bailers.
    Senior Member canam10's Avatar
    Default Self Bailers.
    Do they still make the square self bailers that are on most all the Biesemeyers ? If so where can I purchase them. Tim
    Senior Member Nailhead's Avatar
    Valencia Ca.
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    I have them, the stock plastic ones or in Billet.
    Default Thanks
    Thanks Guys,
    Yes thoes are the ones. Who know they would have been listed as drain plugs. I kept serching for self bailers and nothing would come up. Rex I'll give you a call later today. Tim
    Senior Member poncho's Avatar
    SE Mass/Bering Sea
    Rex, of all the self bailers which do you like the most?....The Stevens had the square ones and i will need 2 for the Canyon.
    Senior Member 540mikey's Avatar
    Jun 2010
    Lake of the Ozarks,Mo.
    Does anyone out there use these on v-bottom boats ie: daycruisers?
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I still don't understand why you v-drive guys use these vs a bilge pump that you can run any time you need to?
    gn7 is online now
    Geez Shaun, because ALL flats are race boats, don't have alternators and run mags. Duh!
    LINK:GN-RACING.COM
    Placentia, CA
    I run both, if a twig gets caught in the j drain, oooops!
    steveo143 AKA DiMarco 21 II
    RIP Davey B and Denis
    San Clemente, Ca
    Quote Originally Posted by steveo143 View Post
    That's exactly why I've never understood these! I feel like they are a disaster waiting to happen. I was at the river a few years back and a guys boat was full of water, all he had was j-drains. He jumped in the boat and tried to fire it up, his buddy's had to hold the boat above water so he could get into the boat because his weight was seriously all it was going to take for it to go under. Luckily he got it fired and he went out cruised around for a bit and then put it on the trailer. I run 2 1000 GPH pumps in my boat!
    Does this rule apply to all vdrives, because your doing pretty good with that pleasure boat of yours!
    gn7 is online now
    They are a disaster looking for a place to happen. If you don't check them everytime you get out of the boat, at somepoint you'll wish you did. The rubber also tends to distort in the presence of petroleum products and not seal.
    We use a 2" diameter bail on a manual linkage. But if you forget to close it when you stop, the boat fills up FAST!
    LINK:GN-RACING.COM
  13. #12
    Senior Member CHURCH MOUSE's Avatar
    Greater downtown Bass Lake
    I have JDA J drains on my 71 Hondo Church Mouse but I screw in my rubber drain plugs from the inside for backup
  14. #13
    Senior Member Pm/pe122's Avatar
    Oct 2010
    In a jet application , ( v bottom ) a bildge is ideal , but in a flat there will always be an inch or more when the bilge pump cavitates . There fore the j drain system i find to be the most useful . If your boat leaks , its best to try and correct ! I dont know any flat owners that dont babysit their boats while tie'd up . And always good practice of making sure there is no loose debris in the hull to hold the J drain open . As for GN 7 's manual deal , thats a freakin fantastic idea !
