Fun speed boat w/v drive - Page 2
Page 2 of 5 FirstFirst 12345 LastLast
Results 15 to 28 of 57
  1. #15
    ..... rivergames's Avatar
    Los Angeles / Parker
    Quote Originally Posted by love2flymn View Post
    Awesome..We'll have to keep in contact then to compare findings.
    I am thinking now that the best option would be for me to do a direct drive... I also thought about just buying a trashed jet ski and mount all the necessary parts in the bottom of the boat but IMO jet drives are way too energy inefficient (you spend way more $$$ on gas than is necessary)
    I was thinking about finding a wrecked tubocharged wave runner and mounting all the hardware onto the boat. I don't think I could live with having a jet on my boat though
    I believe it all comes down to which type of hull you obtain (And how much money you are going to spend)
    Even though it is a little project, you will still be spending a ton of money for the rigging if you go with a v-drive or direct drive. Thats why it would be cheaper to find a jet ski and swap the hardware to a boat.
    Life is too short for a slow boat
    Quote Originally Posted by Tor View Post
    Balls drop, balls grow, and balls eventually get placed into a woman's purse. That's usually when the hard passes in front of Fox's stop and the busting of youth's balls start
    Jun 2012
  4. #17
    Jun 2012
    Although I agree jets aren't the most efficient drive, I have a hard time considering this thing a jet drive impellor. More like a prop in a tube with a directional discharge.
    The thing with jets though you are actually using the propulsion of the water to propel the boat (a demonstration of newton's third law)...with a prop in the water you're actually "screwing" it through the water. Basically it's pulling your boat vs. the boat being pushed by a jet stream of water.
  5. #18
    Senior Member the bandit's Avatar
    Default Love2flymn
    I think ya got a great idea! With your tallant ya should be fine. 1 of mikes lil hydros & a v-drive will be bitchen. I saw a small flat @ cfw with a 4 stroke motorcycle engine-v-drive & not only was it cool it worked! Named boatercycle. I think smash [sanitarium flat] has pics. Hope this helps. Andy
  6. #19
    Member RaceRed's Avatar
    Nov 2009
    North Tx
    Pulling ??
    Real Men Show Their Feelings
  7. #20
    Jun 2012
    I'll be designing and building the hull myself too. I really like the hydro/pickle fork look so that's what I want to go with.
    I know with radio controlled boating a surface prop is much better than submerged drive. What about in the big boat world? Is it best to just stick with submerged?
  8. #21
    Default I hope?
    Is this for real or just bullshit? If for real all are tryan ta help ya, if bs go elsware! Andy
  9. #22
    Senior Member rampgirlll's Avatar
    Jun 2010
    Ft Worth
    Ellison hulls (picke forks) were designed from the little RC boats. They are now the fastest hull in drag boat racing. The sponsons are removable and depending on motor placement and angle of your vdrive, the sponsons can be shaved to fine tune how it rides or pushes thru the water. Now the outrigger style hull that I am speaking of that holds the current ET and MPH records has a w drive because it has two surface props.
    I would like to see a 100 cubic inch motorcycle engine turn twins. Maybe a new avenue for s&s motors?
    Wwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eee
  10. #23
    Jun 2010
    Ft Worth
    Crap never mind. I meant to ask what color are ya gonna paint it?
  11. #24
    Jun 2012
    Quote Originally Posted by the bandit View Post
    Why would this be bullshit? I'm very ambitious about building this. I just want to make sure I'll be able to stay within my financial bounds and make sure it's actually going to be a fun boat. If I can't make the v-drive reasonably priced I'll just slap on a 50 horse outboard for now.
    I think I would be going with about a 1000cc motorcycle engine and do direct drive. I will be getting the motorcycle salvaged so $500 cost there. Are stuffing tubes and drive shafts easy to come by used? And a propeller, how much am I looking at there? And how do I know what sized prop to use?
  12. #25
    Jun 2012
    Oh...I plan on painting it red btw. I thought then I could call it "Red Rocket" but I'm not sure my wife would like that very much.. Also I don't think I would be doing a twin drive. How do I do the prop then? Keep the boat flat bottom in the back and ride the sponsons and tail of the boat or hang the prop down a bit and ride front sponsons and two rear sponsons.
    My only other concern I came up with was that these hydros probably don't take on waves the best. Lots of big boats on the river so often times you'll come across 2-3 ft swells. I suppose if it's fast enough I could just drive around them. Or make the hull sturdy enough to jump them. But then if I'm going fast enough I could have a blow over. I guess I'll live and learn!
  13. #26
    Jun 2010
    Ft Worth
    If you want her thumbs up on the project let her name it.
    Not many people can pull twins off so don't sweat it.
    The only direct drive boat I have ever seen had some kinda odd angle on the prop shaft that made it extend a good 2 feet beyond the rudder. It was a shin biter.
    Most hydros sit pretty low in the water, especially the back end, but since your putting a much smaller motor in it, who knows how it will sit in the water. Good luck.
  14. #27
    Lake Havasu az.
    It's a torque deal. bike motors have a high hp to weight ratio at high rpm but very little torque on the bottom end. Try putting a little 110 hp in 3 gear from a stop and try to take off. Building something small with a prop would be more work than it's worth considering how simple/cheap it would be to wack up a jet ski drive system a graft it into any kind of hull you could find/build.
    Think....prop/cooling system/exhaust.
    Jet ski motor uses crank for centerline of drive, bike motor output is way offset if you use trans and you pretty much have to, there is no easy way to mount output shaft on the end of the end of the crank.
    Closest thing that might work....Newer Honda gold wing motor.
    Dead as simple 6 cylinder 100 hp @ 5k 100 lb. torque @ 4k out put shaft come straight out the back almost in the middle...Trans might be be usable with a prop.....just understand that boats with props only need 1 gear....
    I'll concede, but
    David Olsen of Tamarc Fl. tricked his mother into giving him $27,272.50 and yet refuses to help his 94 year old mother in any way.
  15. #28
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    If you are concerned about money, and it looks like it, you might as well give up now. When you start pricing v drive parts you are going to crap your pants, especially if you think $500 bucks for a motor is pricey. You will be way better off doing a jet dealeo than a v drive. The props will cost more than your motor will. JMHO
    Steve
