You are building in place nobody ever goes....Prop is the most important part on the entire deal and you have so much to learn
you will either make a career out of the project or burn up all of your spare time and never finish it.
The post just above yours shows that I'm not actually going where nobody ever goes.
Yep, start in gear. Transmission in a boat...actually more like a stall converter....is water....the gearbox is how you get the motor in the right place to balance the boat and it's how to get power to a prop shaft that is installed at a very precise angle and has gears that allow prop shaft to be overdriven from 10-60% Props need rpm to work because of slipage. Propshaft on my deal spins 7-8k rpm.
Thanks for the information.
Good luck with setting a deal up for outboard and swapping it to v-drive....might as well set it up hovercraft while you are at it.
King of thrift? lol I built a 'track cart' Sorta go cart with tracks.
2 snow machine track systems set upside by side with a 1200cc 4 cylinder honda wing motor in the middle turning a golf cart differential with a disc brake on each side and separate master cylinders and levers to steer. 30" tall with a roll cage and semi-reclining seat supported with springs/shocks. Geared it down to run 75 max and used ignition interupt/electric shift....Spent less than 500....169 of that was for shifter...All the parts were just laying around the shop and i had a tig/mill/lathe....got to drive it 5 times, guy walked up with $5k cash and i said SOLD.
Sounds like fun.
You are in way over your head with a v-drive deal...they are way more complicated than they look....it's finely balance piece of machinery...upset that balance and bad things happen.
I understand the complications of finely tuning a race boat..I'm not looking for that. I'm looking for a cruiser. Something just fun, not competitive. I also understand if you make one false move going 100mph bad things will happen. I'm not looking at breaking any water speed records here, just something to cruise around with. My basic thoughts were..if you can get 35mph out of a 25 horse outboard on a small boat, why can't you get 45 mph running a direct drive with a motorcycle/snowmobile/ATV/PWC engine? Like the post said above this one, many of these boats can be built with stuff laying around and can be thrown together. I will learn as I go how to tune it to maybe get a few mph extra out of it. Maybe some people that are nice could help me out some.
I do understand you are only replying to me asking if I should not do this but I feel the reasons given aren't substantial enough to not at least give it a try.
Wanna build something cool? copy this...silly little 750 cc jet ski drive
Jet Dinghy, Build and test, NZ - YouTube That there is basically what I want minus the jet drive. I refuse to go jet drive
