No Autoclave carbon fiber
Page 1 of 2 12 LastLast
Results 1 to 14 of 24
    Jul 2011
    Spokanistan
    Default No Autoclave carbon fiber
    Just throwing this out to see what conversation it sparks.
    The material is a non-autoclave carbon fiber that sets as if it had been
    through autoclave (neat technology), can stop AK and 30.06 round
    at PBR of 40feet, wont burn (stealth fighters can catch fire),
    can be exothermically (structural bond) attached to closed cell foam.
    And some other microscopic cool additives. Material can be used in current
    fiberglass boat molds without destroying it.
    picture is a test panel with hand held torch taken at 2pm today, foam wont burn either.
    What do you folks think?
    Senior Member rampgirlll's Avatar
    Jun 2010
    Ft Worth
    How's it do when it barrel rolls at 200mph?
    Wwwwwwwwwweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eee
    Senior Member fc-Pilot's Avatar
    Peoria, AZ
    Using fireproof resin? We have used it with good success.
    Paul
    Senior Member kurtis500's Avatar
    Interesting. I deal with autoclave and OOA materials all the time. Here's the questions for you, 1. Epoxy, BMI, polyimide? Which one? 2. Curing requirements? Oven, room temp? 3. Prepregged? VARTM? 4. Carbon is not usually used as a ballistic material. Aramids generally handle that. I see the 'foam' is the bulk of the material here so I'm assuming this handles the ballistic impact. 5. Is the foam machined from a casting or 2 part liquid? 6. The carbon looks like its around 1/8 on both sides. Correct? Which means this was probably cured under vacuum and probably temperature? 7. What did you mean by exothermally bonded? Im guessing this is heat cured to the foam. It will be interesting to see the answers. Current boat molds are typically gelcoat/fiberglass in construction and have a low Tg.
    gn7 is online now
    Quote Originally Posted by kurtis500 View Post
    Oh, I assure you, it will be interesting.
    You may wish to gear up though.
    LINK:GN-RACING.COM
    Any updates?
    You still there? Looks interesting..still looking for some info
    Jul 2011
    Spokanistan
    Default The ride should be fun...
    Quote Originally Posted by rampgirlll View Post
    the ride should be fun, the material shown is 5x stronger than fiberglass, it can be made stronger to suite
    plus the foam wont fly off and is integrated on all surfaces.
    Jul 2011
    Spokanistan
    Default the Pic
    Cures in less than half an hour, no oven, chemical drivin, carbon is not typically used as ballistic material however it is easily done (well not easy) but kevlar requires several steps to be a good boat material, the stuff is water loving.
    the foam in the picture was just a mock up panel, so not to scale, and the foam is not the ballistic impact, foam is not machined, poured inplace, again process does not harm fiberglass. We can talk more in private if you looking at using for product to be sold on market.
    Jul 2011
    Spokanistan
    Default fire bad
    Paul
    yes some good fireproof resins are available, the one being put to the test is a spec material
    not available to general public and produced under license.
    Jul 2011
    Spokanistan
    pm me
  13. #12
    Im actually curious about the specs on the resin. You probably have a data sheet?
    Is this a polyester/vinyl ester/iso/ortho type resin or an epoxy?
    There's a lot of resins and resin blends out there for many reasons. The best thing to promote the resin is to openly give the key advantages and lab test data. Theres no engineer in the world who will move forward without it..
    Heres an example of an out-of-autoclave material with a spec sheet http://www.in-tec.com/news/X5320_info.pdf
    Sounds interesting, lets see what you got. I have connections..
  14. #13
    Jul 2011
    Spokanistan
    Default I have it
    Yes the docs exist from MSDS to lab performance, recipes and tech are patented, lab testing conducted at various universities, indie labs, and gov. Wont post spec sheets here, but I can send you the data
    sheets and sample, if its for manufacturing boats and you would like to do so by offering the same product at the same price just lighter and stronger. On the previous about car vs kev see pics below.
  15. #14
    Jul 2011
    Spokanistan
    Default If you have preference.
    The strength and performance improvements are not predicated on the chemical type, it comes down to additives, timing, and dependent reactions, so you could use any of the above, which would you prefer.
