Originally Posted by
SofaKingFast
This is only a question, because I just did it. But are you sure the gears are in the right way? The only reason I ask is like I said I just put mine in wrong when I switched to the 25%. Anyways once I flipped the gears over I couldn't pull more than 5100-5200. I have a 454, 396 closed chamber oval port with a large cam and at the time running a single 750 demon. I came from 15% where I could turn past 6200. Currently I'm running 18% with the same motor but with a mag a dual 660's and I pull about 5800. I'm running a 11-5/8x15 stellings prop. But like I said if you need more gear I have the 25% that I need to get rid of. Good luck
