Building Baffles? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 16 of 16
Building Baffles?
  1. #15
    Emmett, Idaho
    Trevor, performance wise, my experience is those suck. We ran those for 2 qualifying passes in our drag car. In a 650 HP SBC, they killed 3 tenths and about 7 MPH. Sounded like you put a bag over the exhaust. Pulled them out and threw them away. But, if all you're trying to do is show an effort to quite it down to LEOs, it's a cheap alternative. We just try to run the flat places where noise isn't an issue....
    hey dave hows it giong.
    when i installed them i ordered them a 1/2" smaller in diameter, and made spacers to shim them to center of the pipe (bolted through all 3 tabs), it left a about a 1/4" space all the way around the outer edge of the cone. im not racing (yet) so they work for the le's.
    A legend to the DNR vdrive502's Avatar
    Lake Hallie,WI
    Default Test results
    I tried the cones with steel wool wrapped around them on the inside to pass a db test lets just say the DNR was not impressed 107 db!!! I did take a cherry bomb muffler and cut it in half and weld up the open part where it was cut in half to get good results enough to pass the db test of 87db @ idle 4 feet out and up from the end of the boat and @ a plane @ 50 feet with water both times.
