Exhaust tips
Results 1 to 11 of 11
Exhaust tips
    Senior Member namba860's Avatar
    Las Vegas, Nevada
    Default Exhaust tips
    Do I need to run a flapper in this exhaust tip? I don't see anywhere they could be attached from the inside and don't really want an external flap or is that my only choice?
    Lookout I'm Crankin it Baby Rattle Can Lou's Avatar
    Boise, Idaho
    My opinion is no...but I want other people to weigh in...Camshaft might make a difference...mild cam no, wild cam maybe yes???
    Senior Member CampbellCarl's Avatar
    Whittier, CA & Katherine Landing
    That thing going to run snails or a straight shot to the log?
    Originally Posted by Rattle Can Lou
    Again, if I came across as a v-drive snob..I apologize,
    Mike
    Las Vegas, Nevada
    straight shot mild cam shaft
    Senior Member the bandit's Avatar
    Default Exhaust
    I am with rcl on this! Do not shut the motor off at 2000 rpm & up! Any ? Call or pm me. Andy p.s. Nice ship!!!!!!!!!!
    Las Vegas, Nevada
    Im more concerned if it takes some chop over the back when the engine is not running
    Boise, Idaho
    If it's a mild cam then I would not worry a bit...I always park the boat nose out and I would recommend that...your ports are low in the transom so you've got maximum drop...good to go..IMO
    And if you DO run snails...I will personally consult an attorney and ponder legal recourse...just my thoughts...
    Just some words to ponder..."always flaps before snails"...
    Quote Originally Posted by Rattle Can Lou View Post
    You and Fairchild back on speaking terms?................
    Mike
    Lurker Tahiti350's Avatar
    Pacific Northwest
    The Spico I got has Supertrapps in the exhaust tips... should work about the same as flappers...
    Senior Member Spike Morelli's Avatar
    Jan 2012
    San Fernando Valley
    I believe Glenwood Marine Equipment can supply you with brand new exhaust trumpets, with a flapper, which attaches inside of the trumpet, so it's fairly attractive because the flapper is hidden. I have a pair for my own ski flatbottom. Personally, I like the "burble" of thru-transom exhausts at the waterline...flapped or not. I think I would do all in my power to avoid having to use exhaust risers ( "snails" )just from a purely visual standpoint.....jet boaters use risers, but if you have a jet boat, it's a foregone conclusion you're not worried about visual cool anyway....
    punk ass kid warpt71's Avatar
    SYV, CA
    I thought that if the motor sat high enough in the boat so that the exhaust ports were above the water line there wouldn't be a way for the water to get into the heads? Seems that it would be an uphill battle for the water....
    I'll paddle my flat before I drive anything else!
