Starter Problems need help
Results 1 to 9 of 9
    Senior Member HL9000's Avatar
    Las Vegas
    Cool Starter Problems need help
    I had a pro-line starter last year, Tilton style. The best i can describe is the starter makes a Zinging noise when ignition is turned. If i keep taping it multiple times it finally engages to turn motor. I tried shimming it last year with up to 8 shims which is about 3/8" down. Still had the problems end of last last year. So i figured i would try a different starter after talking to Mike at Prime. I bought a new one from Prime Marine to see if if that changes anything. I installed it today with no shims, still same problem. I can tap it until motor engages and it will turn the motor over eventually, but after the motor turns over a few revolutions, it stops turning over the motor and starts that zinging again with no engagement. Could it need more shimming down? Any help would be appreciated??? At wits end!!!
    Peoria, AZ
    With the battery disconnected, manually pull the starter teeth out until it meshes with the flywheel. Of course, you may need to slightly rotate the starter teeth until they are fully engaged. You should be able to slide a 1/8" rod/drill bit/etc. between the top of the starter teeth and the bottom of the flywheel teeth when it's perfectly aligned. To achieve that proper space, you'll often need to add shims. We've taken some starters off a BBC that used no shims and placed another on that needed three or even four at times to properly mesh. I suspect it's imperfection in the machining processes of these manufacturers. I sincerely believe some are machined to expect the use of multiple shims.
    Foxwell Motorsports
    N/E Tennessee
    Looks to me like you've pretty much worn the ring gear out. It's hard to tell from the pics, but from what I can see on the teeth, it doesn't look like you've got full engagement when the starter does hook up. Now that you've worn down the teeth on the ring gear, it's made it ten times worse. Looks like you've got a lot of corrosion on the ring gear as well which doesn't make for smooth opertion. Just some things to consider.
    Las Vegas
    I put 2 shims in which fixed the problem. Its cranking over every time now... Hopefully that ring gear will do for a season or so? Alluminum next fly wheel...
    Foxwell Motorsports
    N/E Tennessee
    Quote Originally Posted by HL9000 View Post
    Good deal. Put some grease on the ring gear and it'll help. Just a little will go a long way.
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    Quote Originally Posted by The Doctor View Post
    I'm having similar problems. Shimming only hurts my problem. I can't seem to get a good mesh and the ring gear is getting eaten up. A stock starter used to have no problems but mini starters(2 in a row)don't seem to get a close enough fit.I'm going to try surfacing some material off the starter and if I go too far I can use shims to get it back. I never thought of the grease, which I will try and I got a backup flexplate to replace this backup flexplate in case I get a good fit.
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
    Las Vegas
    Ok, I will. Thanks for the info. Do you have any specific grease you would recommend. Also do you think i should spray the flywheel with something like WD40 to cut down on that rusting from condensation.
    A legend to the DNR vdrive502's Avatar
    Lake Hallie,WI
    The only time I have had a problem a starter is when the real problem was the flex plate. Make sure you are using a good aftermarket flex plate and the teeth are all in good shape not a stock P.O.S. they are to thin and flex a lot.
    Foxwell Motorsports
    N/E Tennessee
    Good ol' wheel bearing grease will work. Just a film thickness applied with a small brush will do, so you're not throwing it all over your bilge. WD40 will evapporate in a few days,. Better to use something like LPS2 or 3. Better yet would be to remove the flywheel (don't know what trouble that would be) and have it cleaned and painted or powder coated.
