T-deck Runnerbottom RC Boat
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 43
    Senior Member PE 316's Avatar
    Livermore, CA
    Default T-deck Runnerbottom RC Boat
    A buddy of mine will be taking delivery of this RC boat hull in the next couple of days.
    (It is the first "open boat" flatbottom out of the mold)
    It will eventually be rigged with a minature billet v-drive and a nitro RC engine, etc...
    Livermore, CA
    The OPEN boat was created off the mold of their CAPSULE boat...
    Castro Valley, Ca.
    How big are these boats and what type of powerplant is normally used in them. Also a contact number would be nice. I'm just finishing up a 5' Higgins style PT Boat from WWII, and am thinking one of these could be fun depending on size.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Livermore, CA
    The new T-deck runnerbottom measures 46" long and weighs 4.5lbs as pictured above.
    Dana Wilson of "DaVette Boats" (the builder) can be reached at the following e-mail address: dkswilson@bendbroadband.com
    Dana Wilson of "DaVette Boats" (the builder) can be reached at the following telephone#:
    (541)815-7052
    According to the builder, he is running "45mph on the GPS with a 275 stock prop and a M6 Zenoah" engine.
    The following link will take you to a website announcing the availibily of the CAPSULE flat, its specs, how much $$$ and where to get some of the other components to complete the build:
    http://rcdragboats.com/Drag_News.php
    News Flash!!!
    New 1/5 Scale Runner Flat Bottom
    Dana Wilson at DaVette Boats has designed a new TAF Runner hull! The Davette is now in production. All boats are sold assembled and primered ready for paint with 5" engine rails installed . Engine rails and transom are made of 1/4" 5 ply baltic birch plywood. Dana also makes an open cockpit version of this hull.
    Computer-designed and CNC-Machined from billet aluminum, these V-Drives replicate full-size V-Drives. Shipped with 1:1 gear ratio, several gear options are available. Ball bearings support the stainless steel drive shafts in both front and rear. Precision stainless steel spur gears provide the force of the drives. Specify motor and drive system desired (flex square cable, flex collet cable, or solid shaft). Available in both 4" and 5" mounts.
    How cool are these?!? Spun aluminum fuel tanks complete with vertical mounting brackets. Turned from 6061-T6 aluminum, these tanks feature "O"-ring sealed end caps, brass fuel fittings, and all fasteners for mounting. Sizes in 4oz. for smaller hulls, and 8oz. for larger models and gasoline
    The M6 engine modification is quickly becoming the engine of choice for competition model boat racing. Higly modified, providing sustained RPMs over 17,000 @ over 4HP. This engine is perfect for competition model boating powering Vee bottoms, Catamarands, Hydros, and Outriggers. The M6 is designed to be used clutchless and requires our Dry Tuned pipe system with 2 inch powerband for proper operation.
    Features
    High Compression
    Relieved Piston
    Lightened Piston to 21 grams
    Lowered Intake Timing
    Raised Exhaust Timing
    High Hat Exhaust Porting
    Copper Coated Base Gasket
    Castro Valley, Ca.
    Thanks for the response and info, looks very interesting, and the size make it very attractive, looks like a great winter project.
    Larry
    62 Bel-Air 409
    2016 Corvette Z51
    Livermore, CA
    Now for the disclaimer...
    I have no financial interest nor am I affiliated in any way with neither the RC boat builder nor any of the various component manufacturers.
    I am only passing on the information for those that might be interested in an RC version of the boat that so many of us enjoy!!
    Discovery Bay, CA
    Hey Mike, I want to see your full-scale runner bottom out rippin' passes on the water next Summer! That RC stuff is cool, but your real-deal is definetly WAY cooler!
    Livermore, CA
    Quote Originally Posted by Rayzor View Post
    THANKS!! I'm either accumulating parts & pieces or working on it here and there almost daily (when the wife isn't busting my ba!!s over it anyways).
    Senior Member kh79909's Avatar
    Pomona CA
    Default Price
    Quote Originally Posted by PE 316 View Post
    I know the age old saying is if you have to ask how much something cost you can't afford it but I got to ask, what does one of these things cost? And what is the cost complete ready to drop in the water?
    a.k.a WHIPLASH #180 VoodooCanoe's Avatar
    Oregon City, OR
    looks like a tr-4 with a Kurtis cut out! Very cool!
    For a extra 7k you can have one of these installed!!!
    http://www.conleyprecision.com/online_videos.htm
    "...if a well set up Canyon don't make your naughty parts tingle, you better check for a pulse ..." DAVID 519
    "That global warming shit sure is cold!" - Suicyco
    '77 Hondo GT rampage's Avatar
    Reno,NV
    I would say Hondo GT.
    Senior Member Futs's Avatar
    Orange CA, Big River
    they are badd ass!!!
    Livermore, CA
    The boat is now ready to be shipped here to the Bay Area this afternoon
    Livermore, CA
    Here is the builder's own capsule boat being demoed...
    http://rcuvideos.com/video/DaVette-R...b-surface-driv
