Lemon headers
Page 1 of 2 12 LastLast
Results 1 to 14 of 27
Lemon headers
    Nov 2008
    BALLANTYNE NC
    Default Lemon headers
    good or bad !!
    Senior Member CampbellCarl's Avatar
    Whittier, CA & Katherine Landing
    Post this in the parts spam section.......or ask the mods to move this thread.
    Carl
    Nov 2008
    BALLANTYNE NC
    Default lemon headers
    Is there any one else out there that is running lemon headers on there v-drive, talk is they ad a little hp,is that correct !!
    WERD! HaulinAss's Avatar
    Gilroy
    Good or Bad? Not sure exactly what you are trying to ask.
    Dan Lemons has an awesome product I have them in 2 of my cars. Most likely Dan will be making a set of them for my boat as well.
    So exactly what info are you trying to obtain?
    Senior Member Factory1's Avatar
    Quote Originally Posted by HaulinAss View Post
    You showed up to the party a little late H.A. He was trying to sell them in here, then he erased the post and wrote that. He wasn't asking about them, trying to sell them rather. As far as making more power? More power is a result of having the optimum primary diameter and length, collector size and length for a given combination. Yes there are other factors as well, do the searches, lots of talk about headers in here lately. Lemons are nice, I like them, but there are a few higher up the food chain. How much do you want to spend? Do your homework, F1~
    Quote Originally Posted by coledust View Post
    Dago Red, and Big Red 1 come to mind, several others run them as well, names escape me.
    Nov 2008
    BALLANTYNE NC
    I have bought two sets of headers from dan for boats,they are nice headers,never seen them on anyother boats,yes i did sell them,so i am asking about them! there are boaters over here that are interested in them,we have a top sportsman car that we need a set of headers for,not to get into a discusion about cars though i wanted to see who else had or liked dans stuff,thanks haulinAss and factory1!!
    I've got enough pics of boats with Lemons, you could make Lemonaid!!!
ID:	63265   Click image for larger version.
ID:	63266   Click image for larger version.
ID:	63267   Click image for larger version.
    Second glass.... There's more, but that should suffice, F1~
ID:	63269   Click image for larger version.
ID:	63270   Click image for larger version.
ID:	63271   Click image for larger version.
    And for a slightly different twist, here's a set of Leamans! Literally!!
    Gilroy
    Quote Originally Posted by Factory1 View Post
    Damn like I said, Dan makes one excellent product!
    Find me some larger tube ones that face downward more, or Ill have to break the pockets on a set of his!
    Ladera Ranch
    I have it on good authority that while they may look good, they wont make more power than a set of Bassetts. Too bad.
    Coors Light Tour - 2010 JDCowboys's Avatar
    Stinkin Lincoln
    I'd bet you even money that a set DG Headers will make more power than a set a bassetts... (as I'm sure any set of TUNED headers laid up correctly could do).
    Gilroy
    Bassetts= Mass Produced
    Lemmons= Custom Per Each Application and Combo
    My guess is the Lemmons would and WILL make more power, that is depending on ones application. If you have a 300HP Olds Motor Id say, well yes then you are right
    However with a real motor, say 700 on up range, what would you use? Bassetts or a Custom Built header? Its such and easy answer, however I await your response
