How to tell the difference between a tall deck and a short deck 454? - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 20 of 20
  1. #15
    Blackwood NJ
    Running on Empty, The actual measurement is from the flat of the deck to the center of the main bearing bore ( center of the crankshaft ). A standard (short deck) block measures 9.800 inches, (just a little over
    9 3/4 inches). A tall block measures 10.200 inches (just a little under
    10 1/4 inches).
    River Rat sangervdrive's Avatar
    Iowa
    Quote Originally Posted by prostock View Post
    10 1/4 inches).
    Thats what I was gonna say. Easiest and quickest way.
    K and D Racing
  4. #17
    Quote Originally Posted by ColeTR2 View Post
    I have never heard of a tall deck 454 only a 427 If you want to build a big cubic inch BBC I'd just go get a new after market block. Once you do all the machine work on a old tail deck block you will find out it's only a few hundred more for a new block that's way better. And you can make it even bigger.
    If you can swing the budget, a big +1 on an aftermarket block... I'll NEVER run an OEM block ever again. I just finished my first tall deck BBC, turned out pretty nice. I found a Bow Tie block used for a reasonable price, so they're around. With a tall deck aftermarket block, it's real easy to build a 632 with off the shelf parts.
    We used spacers on the intake so a standard deck intake works fine. IMHO they look a little jankey but I can live with it.
  5. #18
    1976 Sanger Flattie Running_on_Empty's Avatar
    Indiana
    mortec.com only has 90-91 IV being of any deck difference and my bolck is a 76
  6. #19
    Quote Originally Posted by Running_on_Empty View Post
    That's not correct, go back and look again, they show a bunch of different truck blocks. What is the casting number on yours?
    Any of the other measuring methods mentioned above will help you determine also.
  7. #20
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Damn talk about 25 ways to skin a carrot.
