How to tell the difference between a tall deck and a short deck 454?
Page 1 of 2 12 LastLast
Results 1 to 14 of 20
    1976 Sanger Flattie Running_on_Empty's Avatar
    Indiana
    Default How to tell the difference between a tall deck and a short deck 454?
    92 KURTIS RUNNER BOTTOM
    Its an 1/2 inch, you will need spacers if you use your manifold off a short deck and try to install it on a tall deck. spacers from the heads to the manifold and from the manifold to the block, usually a 427 truck block is a tall deck and the after market blocks can be ordered that way or you can measure it, and i"m sure some one here knows where to measure from
    A ARMED SOCIETY MAKES FOR A MORE CIVIL SOCIETY
    Quote Originally Posted by Running_on_Empty View Post
    Use the casting number and look on Mortec, that's the easy way.
    Otherwise measure from the top water pump hole to the deck surface. A standard deck block will be roughly .200", and the tall deck roughly .600". The actual difference in the blocks is .400", not 1/2". Tall deck is 10.2" deck, standard is 9.8". Note that now days you can buy several different manifolds that fit tall deck engines with no spacers.
    Senior Member ColeTR2's Avatar
    Parker, AZ
    I have never heard of a tall deck 454 only a 427 If you want to build a big cubic inch BBC I'd just go get a new after market block. Once you do all the machine work on a old tail deck block you will find out it's only a few hundred more for a new block that's way better. And you can make it even bigger.
    Gone
    Sparks, Nevada
    Riser oil passage front of block.
    well...not exactly, if it has a riser in the front it is a truck block, but I have two tall decks that DO NOT have the riser and the interesting thing about those two blocks is they have WAY WAY more room in the crank area, cleared 4.25 with tons of room, no where on them do they say TRUCK or MARINE which the other one does, and they are very very late castings.
    Gone
    Sparks, Nevada
    Interesting. I never saw one that did not have the riser. Even the thin wall casting late model replacement I saw.
    Ok. Scratch that. LOL
    Senior Member rocket98's Avatar
    Oro Valley, Arizona
    Back in the day.......I ran a tall deck high nickel simease block......can you tell me what this was .......I was only the driver and they won't tell me anything...........no bs
    Gone
    Sparks, Nevada
    Part # 14044808 "Green Marine" If I remember right.
    http://gilbertautoparts.com/ChevyBar...tie4250td.html
    NO! not at all, as far as I know, if it has the riser then it is a truck, But two others I have where from what I understand, a short run the GM did before they shut the tooling and line down on the 2pc rear seal tall deck mark IV blocks, some one in Las Vegas grap them ALL (More than likely connected) and then sold all off. I got one from Chet Herbert and the other from a guy at the Long Beach swap meet, and both had the worst machining tolerance wise I have ever seen from GM
    Gone
    Sparks, Nevada
    Default Little story
    I used to pick them up at swap meets all the time. Tall decks were all I ran. Once I was at Long Beach and picked up one that was a very clean casting. Much cleaner than any of the others I had seen. Naturally I grabbed that one next time I needed a block. I ran most of them .100 over...just part of the combo I did.
    I bored this one .100 over..thought nothing of it. It split 2 cylinders while the car was just idling...warming up...at the first race.
    That block had a 7.4L (I think?) cast into the side of it. I asked the local dealer about it and he said GM had run short of 427 tall deck cores and had done this late casting which was pretty thin. Never came across another one.
    That's what I was told anyway.
    neither of mine sonic well enuff for a .100 bet you had one of the same deals.
    Administrator Infomaniac's Avatar
    Locust Grove, OK
    How much material is between the water pump boss and the deck? Pretty much a huge visual difference in this area. Between std deck and tall deck.
    And core shift is visual where the water pump cooling holes, cam bearing bosses and oil galley holes are machined relative to the casting bosses.
    I posted measurements back in post #3. If he doesn't have more than one block to compare, or much experience handling them,and didn't want to check Mortec, it should be a quick and dirty way to tell the difference.
