how do you measure the degree of the engine to the v drive? - Page 2
Page 2 of 2 FirstFirst 12
Results 15 to 27 of 27
  1. #15
    Nobody
    Big River, Ca
    Quote Originally Posted by Running_on_Empty View Post
    ok got it....I just wanted to make sure....thank you very much for your help
    No problemo amigo!..
    i don't mean to sound like an idiot....but what do you mean by "on the motor"........like take the carb off and set it across the manifold so its on a flat surface?
    The carb surface is not always parallel to the crank centerline.
    Brian
  4. #17
    Senior Member ColeTR2's Avatar
    Parker, AZ
    No mater how you do it, its very time consuming we use a mock up block and a laser pointer. Can't tell you anything more then that it's top secret. Just joking next time we have it all set up i will post some pictures. LOL
  5. #18
    Quote Originally Posted by GoFastRacer View Post
    On the v-drive flange and the face of the block, both have to be the same. put the finder on the driveline and it should be 1-2 degrees!. Tip: Buy three of them and put one on the v-drive and motor and one on the driveline, saves a ton of time since you can read all at one time!..
    GFR has it, but the one thing you need to remember is the heigth of the motor in relation to the angle of the V-Drive. And do not get it all set up at zero difference between motor and v-drive or you will a vibration only your'e wife or girlfriend will like. Thats where a string line comes in real handy. 2 cent and change back. M
  6. #19
    Rockford, Michigan
    I like a digital protractor because they read out in .1 of a degree increments and you can zero it out on a surface to compare the angle to another.
    http://www.grainger.com/Grainger/items/4LB15
    For EVERY quick jet, there is a faster v-drive somewhere.
  7. #20
    Cantard 71hallett's Avatar
    snow bank
    Just go down to wallmart and buy one of those fancy lazer thingys, then you can play conect the dots!! lol
  8. #21
    Oh Hell That's no fun. M
  9. #22
    Nobody
    Big River, Ca
    That's where the 1-2 degrees come in, can't be dead nuts!..
  10. #23
    snow bank
    Sure it is cause when your done you shine it in the window of the house and watch the wife freak out. lmao
  11. #24
    I've seen guys run them straight. I prefer about 1-2º. Max is 3º for high speed use.
    Crank and vdrive shafts should be parallel but can be offset as above.
    See third pic down for illustration.
    The above link is in the tech links of the on the dyno forum too.
    That is 1 to 3 degrees max per u-joint, isn't it?
  12. #25
    Just an ordinary non wall street fat-cat non Washington insider American in San Dimas, CA
    Blog Entries
    24
    Quote Originally Posted by minimatt View Post
    Correct. They will both be at that degree. If you put angle finders on the 3 places as gfr suggests, you will see a 1-3 degree difference in the shaft angle from the other 2 and the other 2 should be identical (parallel vectors). If either the block (crank) or vdrive shaft differ from each other then you still have alignment work to do. You obviously want to get things square side to side at the same time down the centerline of the boat so the engine is not in the boat cocked sideways. It is possible to get the correct driveline angle but still have the engine off center on one end or the other. The vdrive is a little tougher to get off on a sideways angle assuming you have it coupled up to the prop shaft when positioning.
  13. #26
    What Rex is saying is correct... as previously stated, the offset angles cause the bearings to rotate inside the u joint and make them last longer.
    That said, when we built or drag car (full tube chassis 9.90 car) Chris Alston told us to make the drive line straight at ride height (no offset). I asked him about the u-joint issue and he said it didn't matter that much and it took a certain amount of energy away that could go into making the car go down the track... Thought it might be negligible but we set it up as he suggested. I raced that car for 10 years, thousands of passes driving to the starting line and back to the trailer... U-joints were fine.
    Also, I've always had slammed pick-ups.. again, driveline angles always jacked up trying to get everything right. You could hear the u-joints howl at high speeds, but they never seemed to wear. In my latest dually, we ended up using angle finders to figure out what was wrong, raising the back of the motor and with shims everywhere else and finally got it to quit howling, but it's still not perfect...
    My point is it's always best to do it right, but U-joints seem to be able to take a tremendous amount of abuse and not cause any issues.... Something to consider.
    Solid drive lines have to be as close to perfect as you can get...no excuses. Good luck...
  14. #27
    Atlantic Beach, FL
    OK. First you start out with three fingers of Bookers 125 proof bourbon. This will give your confidence a boost. Next, securely grip a 3 lb ballpeen hammer in one hand, and dial 999 with the other. OK now after stepping in a bucket of red paint... Uh oh... this is the tune up seqence. nevermind.
