Originally Posted by
Moneypit
Then pull it apart and change the flat cam.!!........When you pull the intake remove the lifters and re lube them with the break in lube stuff. Re adjust the valves, be sure you have no water leaks BEFORE you start the engine..Then follow cam break in to the letter. Run the engine up to temp at RPMs suggested by cam break in. Bring the Rs down and shut it off....Drain oil, change filter, add oil, restart and continue cam break in......Repeat as necessary until oil remains clear, no milk and cam is broken in...Did you install the intake?.......9 times out of 10 the intake is cocked to one side.....Leave the weatherstrip sealant for weather striping and put some silicone RTV around the water passages, about 1/8th inch bead, and about 1/4 to 5/16ths inch on the ends. Get it on straight, and it'll seal......The yellow snot aint the same stuff..........MP
