Hullshots "REVENGE" - Page 8
Page 8 of 24 FirstFirst ... 56789101118 ... LastLast
Results 99 to 112 of 336
Hullshots "REVENGE"
  1. #99
    NOSTALGIC V-DRIVES DIMARCO21's Avatar
    Nor Cal
    Thumbs up
    Looks pretty nice to me for not being a "show boat". Good job Don.
    or NP for Short (y) Nice Pair's Avatar
    I want out of Kalifornia
    Hey Don, Nice pics, you get a new camera? Oh! Boats lookin good also.
  4. #101
    Senior Member Hullshot's Avatar
    Dicovery Bay
    Actually every pic is from I phone?
    High Power Marine Drives & Service
  5. #102
    Quote Originally Posted by Hullshot View Post
    "Damn" they look good. when we takin a ride?
  6. #103
    rollin on the river DAVEO's Avatar
    Discovery Bay Calif.
    Smile
    Damn Don that looks sweet! 🚤👍
    Alcohol free since 8/8/1993
    My life is just a dream....
  7. #104
    Dicovery Bay
    making new plates....
ID:	168619   Click image for larger version.
ID:	168620   Click image for larger version.
ID:	168621   Click image for larger version.
  8. #105
    Hey Don, whatta you been doin?
  9. #106
    Member Epidemic's Avatar
    Feb 2009
    I would use a angle stock instead of flat plate on the transom.
    "There are those that have, and those that will."
  10. #107
    Dicovery Bay
    Quote Originally Posted by Epidemic View Post
    I thought about that also. I have a piece of 4x4 1/4" angle on the inside of the transom to bolt through or should I do both or just outside? thanks for looking...
    Epidimic, that was one of the revenge boats wasn't it?? #28?
  11. #108
    someofamitch
    Draper, Utah
    Uhhh, yea. Bob Goettle (Revenge BoatsŪ) just told you what he'd do.
    And your boat is looking very nice.
  12. #109
    Feb 2009
    The inside angle only backs up the center of the transom. The outer part of the transom (behind the panels) is not backed. So what happens is when the down pedal is applied the outer turn buckles will flex the transom just a little. However the tiny bit of flex is enough that the plate in the center moves "X" amount of distance, while the outer part of cavition plate moves "Y" a bit less. Doesn't sound like that big of deal. However I can attest that in testing K-28 that a 32nd of an inch was not only noticeable in attitude but in performance.
    Good Luck, boat looks great.
    Bob Goettel
    P.S. Remember observing this on the trailer, will not show what actually happens in the water. The cav plates in a turn produce many, many pounds of pressure.
  13. #110
    Dicovery Bay
    Bob Goettel
    P.S. Remember observing this on the trailer, will not show what actually happens in the water. The cav plates in a turn produce many, many pounds of pressure.[/SIZE]
    thank you for the response, I do not want this to be ill handling. Also when the plates are mashed what is the aproximate down travel I want to see, my Beisemeyer had just over 2" of travel on a 9" plate? these are 10"..
  14. #111
    ''GHOST of COLDFIRE'' Dossangers's Avatar
    Laguna hills ca
    Why 10'' is that what was on it !
    ''Team BIESEMEYER''
    N.R.K.A. ''The Baddest K'S in the U.S.A.''
  15. #112
    Dicovery Bay
    Quote Originally Posted by Dossangers View Post
    yes, 10" from back of transom. I just remade the plates that came off of it.
