1986 nordic 20 question
Results 1 to 3 of 3
    Aug 2009
    Default 1986 nordic 20 question
    Picked up a new boat this weekend and was trying to determine exactly what engine it has, I took the numbers off the back of the block 3963512 as well as the numbers that are stamped on the left front T7078CPD, I did look these up and it shows either a 427 or 454 year 1971, just wondered how you can tell for sure and if its a 2 or 4 bolt main. I was also wondering if anyone has seen a 20' Nordic with the Bravo 1 drive, everyone i have spoke with says Nordic only offered this model with a jet, It all looks factory to me, but the boat is a 1986 so the 1971 engine code is a bit strange.
ID:	149779   Click image for larger version.
ID:	149780   Click image for larger version.
ID:	149781   Click image for larger version.
    Just Learnin
    Oct 2010
    Default Terrible Crime
    You've been robbed, it's not all original at all... you should sell it to me..
    cheap...
    But as far as useful information the numbers on the head will dictact the head itself. There were allot of different options and you could take a 1971 high compression head and put it on a newer engine block for better performance. The numbers on the block should tell the story.
    EDIT: re read what you'v already done and realized what i said was as useful as tits on a goat.
    http://muscle-car-resto.com/block/
    as a start
    or maybe this one has the info.
    http://autorevival.com/?page_id=18
    It's entirely likely someone swapped in an older 454. Have the heads modified for unleaded fuel and you'll have a higher compression motor with a little most gusto.
    God man man, Samual Colt made man Equal
    Mesa AZ hallettss's Avatar
    It was also offered as an outboard ( I had one) and i have seen a few with out drives.
