Well here I go again another TX build! This one will be Chevy powered with a few extras! Just an extra nice cruiser with a little kick! LMAO, we will see!
[IMG][/IMG]
[IMG][/IMG]
WT
WFL Crew!!!
Sweet bud, glad it finally made it home.![]()
WFL CREW!
http://www.performanceboats.com/cont...-magazine.html
Everybody wants some...I want some too!
All went well! Made it home about 12:00 and Snatch was there putting on his fuel pump! Then we loaded up Sat. and went to the lake and played!
Thanks guys! This will be a nice rig when it's done!
WT
WFL Crew!!!
I'm thinking a blue work cover with white piping.![]()
what a junker!i have a spare Msd Box off of Dads if you want to put it on this boat![]()
WFLC
2011 Performer SS
built by Scott Seastrom.
Just a note to guys doing rebuilds on TX 19's!!! Don't put MONSTER TACH's in the dashes unless you have redone the back board and made it wider! Yes the cool factor is there but, the dash is not wide enough to support a large guage!![]()
FWIW!
WT
WFL Crew!!!
I have had em in 2 boats...but I use autometer. The monster tachs are "stepped" I only drilled a 3 3/8" hole in the dash. Kept my options open so if I wanna put a smaller one in later. Another reason I only went with 3 gauges, if I put a smaller tach in, the spacing between gauges will be a lil wider, but will still be the same gap size between em. But ur right, if I'da drilled a hole big enuff for the gauge to go all the way in, there wouldn't have been ANY structural "meat" left!
2011 Rouse Performance 19'
WFL Crew
