mounting nitrous bottle
Page 1 of 2 12 LastLast
Results 1 to 14 of 18
    Senior Member lupo1904's Avatar
    Feb 2011
    Default mounting nitrous bottle
    today i made some bottle brackets but now that i took out my sub floor i dont know were to mount it.I was thinking about going from stringer to stringer with some angle and mounting the brackets to them.show some pics how you guys have yousr mounted. i really dont want to go through the hull. thanks
    Mar 2010
    Clarksville, TN
    Lupo most of the 1s I have seen are mounted on the sides in front of a fuel tank
    WFLC
    The Man cordog009's Avatar
    New Boston, Texas
    My last one was mounted beside the drivers seat just behind the shift lever. Now I have the brackets mounted to the subfloor that runs from the bulkhead to the rear seat. It's right between the two front seats.
    1984 Youngblood TX-19 SOLD
    Southwest corner AR
    I mounted mine to the seat plate right next to the drivers seat! I made a mount and set it level to the seat board using to brackets screwed to the seat mount! The valve is right about at my thigh between the seat and side of boat!
    I noticed Alter Ego did his the same but put it on the passanger side!
    WT
    WFL Crew!!!
    Feb 2011
    I can mount it to the seat pad but i thought the bottle had to be tilted up so i made my bracets that way, it wont fit in there at a angle but will fit in there level
    Little Rock, AR
    lupo, your thinking is correct, the bottle should be mounted on an angle unless it's been modifed to be mounted standing up.
    Feb 2011
    I never seen a nos bottle monted standing straight up, but is it ok to mount it level?
    Jan 2012
    You guys using a progressive system for your boats?
    Feb 2011
    Rpm
    New Boston, Texas
    On a standard bottle you want the front tilted up with the decal on top, the siphon tube is bent at the bottom towards the floor.
    Feb 2011
    cordogg, that what i was thinking,so thats how i made my brakets but the front of the bottle is to high to fit between my seat and the side of the boat.Looks like im gunna have to run some angle from stringer to stringer just to mount the bottle to, or cut the bracket down but i dont know how much of an angle is needed for the tube in the bottle to be able to pick up the juice.
  13. #12
    New Boston, Texas
    Quote Originally Posted by lupo1904 View Post
    They don't need to have too much angle, 15-20* is usually ideal. The tube should be fairly close to the bottom of the bottle anyway.
  14. #13
    Little Rock, AR
    Nitrous Outlet » Online Catalog » Nitrous Accessories » Bottle Accessories
    If you look at the basic stainless steel bottle brackets on this page, the front mount has a riser that might be around 2". If you can get any angle at all where you're trying to mount them it will probably be fine.
  15. #14
    Feb 2011
    Got it handeled 2" rise
