[For Sale] 4 seat sand rail dual sport car
Results 1 to 2 of 2
    Default 4 seat sand rail dual sport car
    4 seat sand rail. 1915 VW powered, IRS car, Rancho built bus trans w/ super diff and welded 3-4 close ratio gears. 930 CV's, chromoly axles, Sway-away torsion bars in rear, 10" Fox 2.5 Res shocks rear, 10"Fox 2.0 emulsion frt shocks on 6" widened beam. PRP suspension seats frt, fiberglass buckets back w/ crow 4 point harnesses. Car currently has dual 40 IDF carbs, but I also have a complete Car Craft turbo set up that bolts on in an hour. With the turbo installed, the car will take 4 adults anywhere in Glamis. Comes with a set of Desert Trac's in great shape, a set of paddles in very good shape and a set of skinny rear tires to fit in a toy hauler. Also have a tandem axle car trailer. Car just had complete freshen up, runs and looks great. $7500.00 for car and trailer.
ID:	444705   Click image for larger version.
ID:	444713   Click image for larger version.
ID:	444721   Click image for larger version.
ID:	444729   Click image for larger version.
    Oct 2010
    LAS VEGAS,NV/Ft Wayne-in
    Was thinking if you still have the turbo setup???
