1974 VW Beetle Baja Bug. +6 front beam, +6 front arms, Fox coil overs. Power rack and pinion steering, spare tire under one piece fiberglass front end with tool less hold down. 3x3 boxed arms in the rear with Fox dual bypass shocks. Full tube cage front to rear with removable engine cage. All LED lighting with curved light bar. Fresh 1915cc with aluminum case. Engine was built May of 2013 with less than 30 hrs on it. Airworx T3 turbo blow through design. Dual Weber 44's. Built 091 transaxle. Beard front buckets and Beard rear bench with Crow harnesses. The whole interior was sprayed with Line X. Serviced April 2015. I bought it for my wife to drive around on the farm but she doesn't want to shift so ended up buying a polaris ranger instead. Message for more info. $11,500 obo
Turbo Baja Bug Long Travel
