[For Sale] 2005 421cc cheetah PV Yamaha banshee $4500
Results 1 to 1 of 1
    Jun 2015
    Visalia, ca
    Default 2005 421cc cheetah PV Yamaha banshee $4500
    Getting out of the sport and persueing other interests....
    For sale is my highly modified banshee. It has a 421cc cheetah power valve motor set up for extreme duning or drag racing. I built this motor in 2006 and have maybe 15 hours on the motor since the build. Motor is running 175psi in each cylinder with 20cc domes. I have 17cc domes to bump the compression up over 200psi for all out drag racing. Ive only ran it on 110 race gas. Will come with a full set of dirt and sand tires. Sand tires 22x8x10 GBC dune trackers (front) and 22x11x10 9 paddles hauler extremes( Kevlar enforced) buffed bead to bead(rear). All rims are Douglas rims, can't remember if they are black or blue label since they are painted black.
    Here's the mods.
    4mil 421 cheetah power valve motor
    +5mm rods
    trued and welded crank
    Modified shift star
    +4 timing (advanced 4°)
    68mm pistons
    35mm pwk keihins w/ K&N filter pods(160main, 48 pilot),
    20cc domes(175psi)
    CPI in-frame SB chrome drag pipes
    +4 round house carrier swingarm
    Magura Hydraulic clutch
    Black PC'd Wicked +2+1 a-arms
    Cascade innovations seat and seat cover
    IMS roll design foot pegs
    All 4 hubs, tie rods, Rear sprocket hub, rear brake disc hub are PC'd vein red
    Both side cases have a flat black and vein red PC Combo.
    Rear axle is PC'd flat black
    Motion pro 1/4 turn twist throttle
    Cr250 boyseen reeds
    New nikasil sleeves in cylinders
    Marvin shaw chrome front coil overs in front set up specifically for the longer a-arms and dune riding
    OEM rear shock with internals set up for longer swingarm and for drag racing.
    Dual pingle petcock
    If you do not know what a power valve motor is... It has valves in the exhaust port that will help give more low end torque at lower RPMs(which makes it a great duning motor). When the exhaust pressure rise with the higher RPMs the valves will rise and open up the exhaust port to allow the motor to breath better for more HP. The conversion kits cost between $2000-$3500.. That's before you buy the bigger carbs, crank, and the exhaust to handle the higher HP.
    This thing is fast as hell and fun as hell when out in the dunes.... Holds its own when drag racing and hill climbing. Only other quads that have beat it is the all out drag bikes. I have it set up as a sleeper and have surprised many people when they loose.
    Extras include, bel-Ray oil, all the jets I have, gas can with 110 octane race has still in it and mixed, flags, and anything I find in the garage.
    Asking $4500 or best offer CASH talks.. No checks, no money orders.
    Willing to trade for a running(preferably) jet boat of equal value or 1000cc street bike...
    Have more pics Upon request
    I WILL NOT PART OUT.... No calls are texts after midnight..email anytime 559-309-3578
    located in Visalia, ca... Willing to meet half way if need to travel
    I also have a 12x6 Carson trailer for sale. $2000....... completely redone
